2022-12-15 10:42 PM
Hello everyone,
During my late extensive work with labels, I noticed that there are 2 selection types. One that is more focused on the text frame and its content, and one where you manipulate the geometry of the label as a whole.
As I later found out there is no way to quickly select multiple labels that would enable manipulation of the text frame only. (type 01 selection in the provided image)
I believe that we should be the ability to quickly select only the text portion, instead of clicking one by one. That would make working with labels much smoother, and much cleaner.
Stefan
Solved! Go to Solution.
2023-03-08 03:33 PM
Hello,
Thank you very much for sharing your idea with us!
I added a wish into our database, which you can refer to as WISH-12585.
I hope we will see it implemented as soon as possible.
Kind regards,
Dani Benjamin
Technical Support Engineer
2022-12-16 01:27 AM
Here is the link to the post that discusses this ...
https://community.graphisoft.com/t5/Document-Visualize-forum/Label-selection/td-p/364803
2023-03-08 03:33 PM
Hello,
Kind regards,
Dani Benjamin
