Read more
Wishes
Radial Gradient Fill - Transparency
DGSketcher
Legend
Just been trying to use the Radial fill to isolate part of an image, unfortunately using transparency defaults to the outside regardless of the concentric rings, which means the bit I want to see is hidden.
1. Please enable moving the rings to invert the colour blend so we can have Foreground or Background pens to the centre. The fact we can swap the ring positions suggests this may even be a bug rather than as designed.
2. The ability to distort the rings to ovals would be a nice improvement. Circles can be a bit restrictive.
0 REPLIES 0
