2024 Technology Preview Program
Wishes
Using Autotext with dimensions
gdford
It would be nice is autotext could be associated with a dimension so that the dimension text could be expressed in various unit types on the same dimension string.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
1 REPLY 1
Mscott
Not sure if you know about this one, but you can show different units on one string by selecting the dimensions followed by the Document Menu > Annotation > Secondary Dimensions > Convert Dimensions, choose the unit type and click OK and you should end up with something like this:
