2 composite wall connection
Zendrix
Hi! Im having some weird behaviour between 2 composite walls that i would like to see if someone can help me understand:
I have 2 types of composite walls. When i connect Type A wall to type B, it works fine below the green line. As soon as i displace it above the green line, it snaps out of the connection and does not ant to connect properly to type B composite wall.
any ideas?
Thanks,
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
5 REPLIES 5
CosminF
That is because in the 2nd case, the reference line (blue line) can "attach" to the reference line of the vertical wall. In the first instance, they are almost overlapping so Archicad doesn't know which composite takes precedent.
A workaround I see would be to use the wall end tool on the vertical wall, I have tried and it intersects "correctly"
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Rene Pahlavan
Cool workaround CosminF - and you are right about the ref lines needing to collide for clean intersection.  You could also adjust the reference line into a better position when you edit the complex profile.
AC27 (Apple Silicon)
macOS Sequoia 15.1.1.
MBP M3 Max (16-inch 2023)
Guru
Walls will only intersect when their Reference Lines intersect. Wall B has a reference line on the outside face, while Wall A's is on the top edge, hence when you move Wall A into the corner, the Reference Lines will no longer intersect. You have a few options;
  • Change your reference lines of Wall B to the inside edge of the wall. Only the horizintal Wall B would need to change.
  • offset Wall A's Reference Line so that it still intersects that of Wall B
  • place a Complex Column at the corner
How well the Wall End tool works depends on where your reference lines are within your Composites and corner... It would not work in the OPs situation.
Ling.
Zendrix
Thank you all for the input.
Trying to change the reference line for the inside makes my type B walls not able to connect, even after using the intersect command:
Z
Zendrix
I had a layer of ceramic tiles on the inside of the bathroom in the same layer as the walls and it was messing with the wall connections. As soon as i changed the ceramic tile layer to another layer and another intersection priority within the layer, things got well again!
Z
