SEO amount and file unsable in 3d. We have an 83 acre site with many SEO
stan-rostas
We have been developing a site model, and we have completed ⅓ of the site, including roads, walks, and driveways. Things were working, albeit slowly, when transitioning to 3D, but they were working. We have now added the other ⅔ of objects to the SEO of the intersection, then subtract upward. The file will not open a 3D view. We let it run overnight, and it is still running. So the question is, where is the information with red flares that states do not create more SEO than a certain amount? We will now need to enter the 2D view and determine how to remove all these SEO elements, which could be done one by one, unfortunately, since we do not have a method to view a list of these SEO elements and eliminate them. I'm not sure what the answer is here, but for Site work and in many instances, building work, we need SEO not to slow down the application the way it presently does, and make the 3D unusable.
Space Craft ed
12 REPLIES 12
Erik Bjornhage
Is there an option to roll back before the latest batch of SEO?
Feels like that would be a quicker option than trying to troubleshoot one item at a time...
Erik Bjornhage : SwedishChef, INSIKT Digital Sapiens, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
INSIKT : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
I guess you are pushing the limits for Archicad.
As for SEO we realized its best to fragment big elements (like terrain, slabs etc) into smaller pieces.
10 elements with 10 SEOs is more performant than one big one with 100 SEOs.
AC 6,5 - 28 | GER WIN | i7-9700K | RTX 3070 | 64GB
stan-rostas
We had over 1,200 SEO objects and 2,400 operations and were unsure where to post, as this seems like an issue core to the program. We saw another post on this forum regarding SEO. Interestingly, after running the 3D view for over 16 hours, ArchiCAD finally eliminated most, if not all, of the SEO operations associated with the objects.
We understand the need for MEP and Structural components in ArchiCAD. Still, all projects begin with the land, and it would be beneficial if land features were integrated with the Civil Engineering aspects of construction. Currently, Microstation and Autodesk dominate this market, with Vectorworks filling the landscape needs, which in turn leads to other professions utilizing their other products.
Space Craft ed
Stan,
I suggest providing a copy to your local technical support to demonstrate the limitations that you have found in the software. There was the post from @James B on SEO usage. I will have a chat with him to see if your experience is the scope of the project he was investigating.
Regarding the need for the Mesh Tool to be improved, I can not agree more with you, it is something on my list. Sadly I don't see anything on the roadmap relating to the Mesh Tool so you will need to identify some work arounds in the short term.
Regards Nathan
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC29 | WIN 11 | Ultra 9 285K, 3.7Ghz | 64GB Ram | RTX4000
Mario Sacco
I had the same problem with a huge model of an hospital.
I think it's a problem the coders can't avoid.
Calculate the SEO of a single element on more element will be always slower then the SEO of the same element divided in more elements. The fact is that the software must create a temporary huge SEO geometry always when there is a change on the model; the SEO geometry is temporary memorarized in AC until there is a change.
Something similar happened to calculate merged fills. If you try to merge thousand of fills is slower instead calculate in more steps part of these thousand fills. For example 100 fills each times. You need more operations but it's faster. But instead of the SEO problem, this can be resolver by the coder.
Codings misteries!!!
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
Eduardo Rolon
Beside splitting the mesh in smaller areas (remember to keep a backup of the original mesh just in case):
Something to try is to have a specific layer priority number for the site elements so that AC ignore the rest of the model.
Also avoid using slabs for SEOs with meshes and use flat meshes since they do not participate in PBCs
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Botonis
Mentor
This is something I never used before and obviously it creates a workflow deviation but just as a test if you convert the whole mesh to a morph does the lag disappear?
You then have to always keep the mesh somehow with those SEO in the background and update it accordingly and then convert it again to a morph....
If you were sure that there is no gonna be any other action to that mesh, maybe the convertion to morph will solve the workability problem.....
Just to be able to continue working
I don't know if you export the mesh as IFC and import it again. You may need to have two files....
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
There is this community made object that could be the answer to what you're doing.
https://community.graphisoft.com/t5/GDL/Is-there-a-tool-object-for-making-a-mesh-with-a-specified/td...
It won't prevent you from splitting your terrain into multiple, smaller meshes but it will drastically reduce the SEO you need to do for roadworks and such
Davor P
This "limitation of software" has been known - just add a few hundred SEO interactions of any sort and model will already become measurably slower. Graphisoft is well aware of this but apart from stating it they don't provide a solution. I have an addon - Find Operators that lets you detect them at least. You can get it for free for AC26.
How many of these operations need to be editable? If some don't need to be live, finalize them then save morphs as an object and replace morphs with the object.
BIM4BIM - by BIM managers for BIM managers
www.bim4bim.com | audit.bim4bim.com
