Janmarquito
Crashing Grasshopper Live Connection
Hi all,
I am using Rhino 6, the latest version, along with Archicad 27, also at the latest version.
I installed the Live Connection Plugin as intended.
The moment I start the live connection in Grasshopper, Rhino crashes immediately.
It doesn't happen when Archicad is closed, and it also doesn't crash when the wrong port is entered.
I've tried several reinstalls and deleted all the plugins, but nothing helped.
Thanks for the help.
1 Solution
Tamas Gaspar
Dear All,
This might be the issue DEF-18943. It is about a crash that happens because during the initialization (that happens after connecting) the plugin tries to query attributes, viewpoints and properties. This requires the Newtonsoft.Json.dll dependency which is not installed via the installer for Rhino 6 as the Rhino 6 runtime already contains this. The plugin is compiled with a newer version of Newtonsoft.Json (13.0) than the one in the Rhino runtime (10.0) which has missing features, and that results in the crash.
To resolve the issue, please copy a newer version (13.0) of Newtonsoft.Json.dll (attached) to the installation folder of the Grasshopper plugin. It is located at Rhino6\Plug-ins\Grasshopper\ArchicadConnection.gha.
I hope this issue will be solved soon.
Regards,
Tamás Gáspár
Manager, Partner Technical Support, Graphisoft
Go to post
12 Replies 12
Aaron Bourgoin
it's a stab in the dark, but try applying the latest AC patch after you've installed the Live Connection.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Janmarquito
Archicad 27 is at its latest Version 😞
Aaron Bourgoin
which is fine. What I'm suggesting is that you apply the latest patch again.
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Janmarquito
I tried it, but that didn't fix the issue. I also attempted a complete reinstall of Rhino and Archicad - but that also had no effect.
Kotetsu
I am also in the same situation.
Are there any users for whom 'Rhino 6 + Archicad 27' is working properly?
OS:
Windows 10
Rhino:
Ver.6 SR35 (6.35.21222.17001, 08/10/2021)
Archicad:
27.2.0 FULL JPN
koiwai
Im in the same boat. Tried with all archicad 27 builds (3000,4000,5000), all of them crashes rhino.
Also i am using the hungarian education version.
Oddly Archicad 26 HUN EDU version works without a problem.
Pato99
Yes Rhino 6 with ArchiCAD 27 - 5003, crash on connection 😠
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
Tamas Gaspar
Dear All,
Regards,
Tamás Gáspár
Hi Tamas.. your workaround works..(i encountered this issue just now)
I hope this is resolve in the new ac27 patch soon   🙂  thanks!
Device name Asus v16
Processor Intel(R) Core(TM) 5 210H 2.20 GHz
Installed RAM 16.0 GB
