โ2024-03-27 01:58 PM
Hi all,
I am using Rhino 6, the latest version, along with Archicad 27, also at the latest version.
I installed the Live Connection Plugin as intended.
The moment I start the live connection in Grasshopper, Rhino crashes immediately.
It doesn't happen when Archicad is closed, and it also doesn't crash when the wrong port is entered.
I've tried several reinstalls and deleted all the plugins, but nothing helped.
Thanks for the help.
Solved! Go to Solution.
โ2024-05-02 07:37 AM
Dear All,
This might be the issue DEF-18943. It is about a crash that happens because during the initialization (that happens after connecting) the plugin tries to query attributes, viewpoints and properties. This requires the Newtonsoft.Json.dll dependency which is not installed via the installer for Rhino 6 as the Rhino 6 runtime already contains this. The plugin is compiled with a newer version of Newtonsoft.Json (13.0) than the one in the Rhino runtime (10.0) which has missing features, and that results in the crash.
To resolve the issue, please copy a newer version (13.0) of Newtonsoft.Json.dll (attached) to the installation folder of the Grasshopper plugin. It is located at Rhino6\Plug-ins\Grasshopper\ArchicadConnection.gha.
I hope this issue will be solved soon.
Regards,
Tamรกs Gรกspรกr
Manager, Partner Technical Support, Graphisoft
โ2024-03-27 02:37 PM
it's a stab in the dark, but try applying the latest AC patch after you've installed the Live Connection.
โ2024-03-27 07:08 PM
Archicad 27 is at its latest Version ๐
โ2024-03-27 07:35 PM
which is fine. What I'm suggesting is that you apply the latest patch again.
โ2024-03-27 11:19 PM
I tried it, but that didn't fix the issue. I also attempted a complete reinstall of Rhino and Archicad - but that also had no effect.
โ2024-04-02 03:17 AM
I am also in the same situation.
Are there any users for whom 'Rhino 6 + Archicad 27' is working properly?
OS:
Windows 10
Rhino:
Ver.6 SR35 (6.35.21222.17001, 08/10/2021)
Archicad:
27.2.0 FULL JPN
โ2024-04-15 08:21 PM
Im in the same boat. Tried with all archicad 27 builds (3000,4000,5000), all of them crashes rhino.
Also i am using the hungarian education version.
Oddly Archicad 26 HUN EDU version works without a problem.
โ2024-04-26 03:18 AM
Yes Rhino 6 with ArchiCAD 27 - 5003, crash on connection ๐
Dear All,
Regards,
Tamรกs Gรกspรกr
โ2024-05-02 07:59 AM
Hi Tamas.. your workaround works..(i encountered this issue just now)
I hope this is resolve in the new ac27 patch soon ๐ thanks!
