Project data & BIM
Read articles about BIM-based management of attributes, schedules, templates, favorites, hotlinks, projects in general, quality assurance, etc.
Articles
Converting old Archicad Files
You can choose from the below listed Archicad File converters to convert your Archicad files to a format which is supported by current Archicad versions. The latest Archicad File converters can be find on Graphisoft.com. You can also find the FAQ on ...
mtron Graphisoft | Graphisoft
  • 25438 Views
  • 3 comments
  • 0 likes
Migrating Classifications
There are a lot of cases – even if it is not entirely intentional when you migrate projects. This happens when content made in an earlier version of Archicad is opened in a newer version. These scenarios can include: simple copy-paste from your old p...
Migrating a Project Using the Archicad 10 File Converter
The ArchiCAD 10 file converter allows users to migrate their files versions 6.5, 7 and 8 to ARCHICAD 10. This file can then be opened in the current version of the software. If you have already installed the ARCHICAD 10 file converter please navigate...
wp-content_uploads_2018_12_Screen-Shot-2018-12-04-at-11.00.07-AM.png wp-content_uploads_2018_12_Screen-Shot-2018-12-04-at-11.00.22-AM.png wp-content_uploads_2018_12_Screen-Shot-2018-12-04-at-11.00.31-AM.png wp-content_uploads_2018_12_Screen-Shot-2018-12-04-at-11.00.51-AM.png
Project Migration Overview
File Compatibility • ARCHICAD 27 and newer versions can open PLN files back to version 17. • ARCHICAD 26 and earlier versions can open PLN files back to version 8.1. • ARCHICAD 6.5, 7.0 and 8.0 files may be opened in the ARCHICAD 10 file converter. O...
