Teamwork & BIMcloud
Read articles about Teamwork, BIMcloud, BIMcloud Basic, BIMcloud Software as a Service, network settings, etc.
Articles
Archicad users experience offline status in Teamwork
Related versions: v19 and newer Possible reasons based on the frequency of occurrence Archicad or BIMcloud / BIMcloud Basic is not up-to-date Make sure that all Archicad clients and BIMcloud / BIMcloud Basic components are updated to the latest build...
Teamwork operations are slow
Related versions: v19 and newer Archicad users experience slow down or freeze during Teamwork operations (Send & Receive, Send, Receive, Reserve, Release) in teamwork projects. Possible reasons based on the frequency of occurrence Archicad or BIMclou...
BIMcloud Server is Not Accessible
Applies to: BIMcloud and BIMcloud Basic from version 19 and above The status of the BIMcloud Server is Not Accessible, but the BIMcloud Manager is still accessible from Archicad or a browser. Users are not able to join projects. Joined projects indic...
BIMcloud as a Service Connection Test
BIMcloud as a Service enables real-time, secure teamwork between architects in the cloud. With your BIMcloud as a Service subscription, you get access to your own private BIMcloud server hosted by Graphisoft in the Google Cloud Platform. No IT setup ...
Error: "Unsuccessful Teamwork operation!"
Related versions: v19 and newer When an Archicad user attempts to Open a teamwork project or do a Send & Receive in teamwork, the operation fails with the above error message. Archicad or BIMcloud / BIMcloud Basic is not up-to-date Make sure that all...
Working from Home with Archicad
At GRAPHISOFT we are doing our best to assist our users during the challenging times of the COVID-19 outbreak.Read this article to learn how we can help you. If you are considering to work from home, you will need to prepare your environment to be ac...
Network Requirements
Related versions: v19 and newer, BIMcloud as a Service Addresses Domain names or IP addresses Before installing any server products, consider how the server(s) will be accessed by clients (Archicad, BIMx) and other servers (BIMcloud). Plan for a long...
wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_2020_04_BIMcloud-connection.png wp-content_uploads_2017_10_Warning_18x18.png
Error: "Error happened while connecting to project"
Troubleshooting Connection Errors in Archicad Teamwork
These are general troubleshooting steps you should take if users are having trouble connecting to the BIM Server in a local area network (LAN) environment. General signs of possible connection issues are the following error messages: "Cannot Connect ...
wp-content_uploads_archicadwiki_teamwork-connectionproblems--sharinghostname.png wp-content_uploads_archicadwiki_teamwork-connectionproblems--terminalhostname.png
