Read more
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Quickly hide cameras & paths on floor plan
Now, to hide Cameras & Paths on a floor plan, you have to go to Cameras>Path and then select Display Options. Not even a shortcut to get to that buried option.
This should be an On-screen View Option, and added to that Toolbar as a toggle.
Richard
AC26 (since AC6.0), Win10
12 REPLIES 12
runxel
Legend
This, and another wish I just shamelessly put here:
I'd like to have sets for display options, because at the moment it's often a click orgy to get the right things show up.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
godi
We should need only a new right-click menu option "hide cameras".
So easy should be.
runxel
Legend
So easy should be.
No, please not. There is already so much in the right click menu. "Hide cameras" doesnt belong there for sure.
Richard is quite on spot with the wish.
dcerezo
How could would it be if you could customize the right click menu to whatever you want? I mean have the usual stuff and then the option to add 3 or 4 more things only you want. Just a thought.
ArchiCAD 26 - iMac 27, Late 2019, 3.7 GHz Intel Core i5, 32GB Ram, Radeon Pro 8GB, macOS Sonoma
The context menu is smart in that in can change depending on what is selected.
I think it would be a good working method to select a Camera, and the "Hide Camera Path" command would then appear in the context menu. When no Camera is in the selection, the command would not appear in the context menu.
dcerezo
I agree, that's what I mean...maybe they can design a way for us to add that to the context menu.
I would love to be able to have "Redefine View With Current Settings" in a right click context menu. If I had a nickel for every time I have mouse over to the view map, right click, then click on that, I'd have lots of nickels.
Not as good of a solution as having this ability in the actual interface of AC, but I've used this method in my templates for 25 years or so. I have pre-saved paths in my camera tool. I have the tool defaulted to "01 Still Cameras" so I can just start putting cameras in the plan without any preparation. But, when I need to hide them, I go to the camera tool and choose "00 Cameras Off"
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 27 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
Johan Stinckens
I really can't seem to understand why this isn't included in the Model View Options!
Adding a section similar to "Construction Element Options" it would be fairly easy to connect the display options (None, Camera's only, Camera & Path, Everything) to different sets of MVO (if needed).
And while we're at it, why not include similar settings for annotations? -> None, Texts, Dimension, All.
Could really be useful when creating clean 3D Documents.
Johan Stinckens
BIM Modeller at Atrium Architecten
Archicad user since April 2014 (v17 - v26) - CC iRT i9-12900 - 64 GB / Nvidia Geforce RTX 3080 - Windows 10 Pro 64
Other than that it's hiking, camping, climbing.
Only if GS gives us back an "Update" or "Redefine" button in the MVO settings.
I would only want to change the camera paths on/off on screen only (I know they don't print anyway).
I wouldn't want the actual MVO combination updated automatically.
See ... https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=69580
