Read articles about Archicad's design tools, element connections, modeling concepts, etc.
Articles
Stair Tool Advanced - How to create a Ramp using the Stair Tool?
There are many ways to create a ramp in ARCHICAD (e.g., Ramp Object), but in this article, we are going to show you how to create one with the help of the Stair Tool. Here is what you will need: a complex profile a Stair with stringers that's all Str...
wp-content_uploads_2018_04_Screen-Shot-2018-04-13-at-15.11.49.png wp-content_uploads_2018_01_Stair_Tool_-Ramp_Profile-e1523363590445.png wp-content_uploads_2018_01_Stair_Tool_Ramp_Finish-e1522941259315.png wp-content_uploads_2018_01_Stair_Tool_Ramp_Stringers-e1523363381524.png
Snow Globe series: Christmas In Space by Kamen Nikolov
Welcome to our series of articles from the Snow Globe Challenge! We invited some of the designers who participated in the challenge to elaborate on their entries, share their workflows and tips&tricks. Enjoy and feel free to drop us a comment if you ...
Joining Wall Segments
Adding new nodes to a Wall when editing it via the Pet palette eventually creates segments which cannot be joined again using an inverse command or such. Though it is not something you could not solve by deleting one of the segments and edit the rema...
Grasshopper Connection Object Guide - Sweep Object
With the Grasshopper - ARCHICAD Live Connection, you can enhance your BIM model with complex shapes that can not be defined easily with the default ARCHICAD tools. In order to be able to properly represent and document these shapes, while keeping the...
wp-content_uploads_2019_08_simple-curve-cover-photo-1024x477.png wp-content_uploads_2019_08_object-search-sweep-1024x752.png wp-content_uploads_2019_08_simple-curve-sweep-divide-1024x576.png wp-content_uploads_2019_08_simple-sweep-curve-offset-to-origin-1024x576.png
Parametric Profiles - Schematic design variations
We're famous for having Tools that can be used for more than their original function. Profiles are used in Walls, Beams, and Columns to create custom elements tailored to the project. Use the parametric profiles to create design alternatives and cust...
wp-content_uploads_2018_06_kitchen.png wp-content_uploads_2018_06_Screen-Shot-2018-06-13-at-13.36.59.png wp-content_uploads_2018_06_3d-editing.gif wp-content_uploads_2018_06_Screen-Shot-2018-06-18-at-12.30.39.png
Parametric Profiles - Adjustable fireproofing
As a newly introduced feature in ARCHICAD 22, the parametricity of profiles can be used for multiple purposes. One of them is to create adjustable fireproofing/insulation for beam or column elements. Later, the thickness can be adjusted by element, l...
wp-content_uploads_2018_06_Screen-Shot-2018-06-11-at-12.37.21-e1544691937753.png wp-content_uploads_2018_06_modifier1.gif wp-content_uploads_2018_06_modifier2.gif wp-content_uploads_2018_06_modifier3.gif
Parametric Profiles - Wall with offsetable skins
A Wall element can be a simple wall and it can also use composites or profiles. Composite structures can be used with Shell, Roof, and Slab elements as well, and can have up to 48 skins with individual skin separator lines However, since with ARCHICA...
wp-content_uploads_2018_06_Screen-Shot-2018-06-12-at-10.29.20.png wp-content_uploads_2018_06_Screen-Shot-2018-06-01-at-15.31.01.png wp-content_uploads_2018_06_01.gif wp-content_uploads_2018_06_Screen-Shot-2018-06-11-at-17.15.09.png
Parametric Profiles - Pointers how to manage your modifiers
With parametric profiles being introduced in ARCHICAD 22, came new attributes to manage, the offset modifiers. With the help of the Modifiers, you can create more intelligent Profiles for Walls, Beams, and Columns, by defining the edges parametricall...
wp-content_uploads_2018_06_Screen-Shot-2018-06-12-at-16.39.09.png wp-content_uploads_2018_06_Screen-Shot-2018-06-12-at-14.48.44.png wp-content_uploads_2018_06_Screen-Shot-2018-06-12-at-15.19.15.png wp-content_uploads_2018_06_Screen-Shot-2018-06-12-at-15.35.24.png
Modeling of floating floor screed edge detail in ARCHICAD
This article explains methods of enhancing the appearance of connections of floors and walls in model section views. Description of the floating floor screed edge detail In most cases the solution for floors to match soundproofing requirements is to ...
wp-content_uploads_2017_11_floating_floor-150x150.png wp-content_uploads_2017_11_floating_floor_detail-300x254.png wp-content_uploads_2017_11_floating_floor2-221x300.png wp-content_uploads_2017_11_floating_floor_profile-300x281.png
Profiler Add-On
The Profiler Add-On allows you to create Object type Library Parts by extruding a profile along a straight or curved path. The new Profiler command will appear in the Design/Design Extras sub-menu by default. How to use Profiler Add-On To create an o...
Creative Uses of Complex Profiles
Original thread is published at AECBytes: http://www.aecbytes.com/tipsandtricks/2008/issue32-archicad.html written by Eric Bobrow Principal, Bobrow Consulting Group Although AECBytes has already archived the original thread of this article, we kept t...
wp-content_uploads_archicadwiki_complexprofiletips--1.jpg wp-content_uploads_archicadwiki_complexprofiletips--2.jpg wp-content_uploads_2012_04_profile-editor.png wp-content_uploads_archicadwiki_complexprofiletips--3.jpg
How to create Balusters in Archicad
Revolved elements can be created using Complex Profiles, Shells or Morphs. In this example we are using Complex Profiles to create custom-shaped balusters. Step 1: Draw Profile Create a Complex Profile of the Baluster that you want to use. Make sure ...
wp-content_uploads_archicadwiki_complexprofilebalustrades--balustercopied1.png wp-content_uploads_archicadwiki_complexprofilebalustrades--balusterready2.png wp-content_uploads_archicadwiki_complexprofilebalustrades--material.png wp-content_uploads_archicadwiki_complexprofilebalustrades--balusterjo.png
automata Graphisoft
  • 1718 Views
  • 0 comments
  • 0 likes
How to create custom Openings by using Solid Element Operation
by Dwight Atkinson, Vancouver, Canada Creating wall openings as windows is not the easiest or fastest way to make design experiments with wall openings. For non-critical work, using an SEO (=Solid Element Operation) combined with a Complex Profile Be...
wp-content_uploads_archicadwiki_createcustomopening--1.png wp-content_uploads_archicadwiki_createcustomopening--2.png wp-content_uploads_archicadwiki_createcustomopening--03.png wp-content_uploads_archicadwiki_createcustomopening--01.png
How to modify the Side Contour of a Wall
Walls in ARCHICAD by default have a uniform height along the whole element. By trimming Walls with Roofs or using Solid Element Operations (SEOs) with the Wall as target and Roofs/Beams/Slabs etc. as Operators, the contours of Walls can again be modi...
wp-content_uploads_archicadwiki_modifythesidecontourofthewall--1.jpg wp-content_uploads_archicadwiki_modifythesidecontourofthewall--2.jpg wp-content_uploads_archicadwiki_modifythesidecontourofthewall--3a.jpg wp-content_uploads_archicadwiki_modifythesidecontourofthewall--3b.jpg
automata Graphisoft
  • 3488 Views
  • 0 comments
  • 0 likes
