Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9306 Views
  • 127 replies
  • 19 likes
Retaining Display Options
I have Section/Elevations markers selected as "As in settings" in the display options, together with Section Depth as "do not show" When I change from the screen display between the Project Map and View sets, the sections default to "Normal" and "Sho...
Circle tangent - geometric correct
This is my first post, and I want to show how to create geometry proper line tangent to two circles. Attachment as .PDF PS: Sorry that this is without any comment, but I suppose that it is clear enough.
Anonymous by Not applicable
  • 3887 Views
  • 1 replies
  • 0 likes
Rendered section
Im trying to edit the sections im creating. Can i shade or even better , render my sections?? .. I say sections, but the renders would be more appropriate on my elevations. How do i create these or will i only get hidden line sections?
  • 5643 Views
  • 9 replies
  • 0 likes
Amending Dimensions
I have dimensioned a drawing to plaster finish, how can I amend the dimensions to relate to the blockwork without having to start over?
  • 3901 Views
  • 1 replies
  • 0 likes
double swinging, double leaf, asymetric 'metal' door?
hi all does anybody know of a freeware double swinging, doubled leaf door where i can set the sizes of each leaf independently to each other? i.e i can have one smaller door leaf than the other. i'd also like to be able to 'oversize' it in a similar ...
Smart Hotspots
I'm looking for a tutorial/info on how to script 2d smart hotspots. Does anyone know where I could find one?
Red by Enthusiast
  • 31456 Views
  • 27 replies
  • 0 likes
Drag a copy, etc. etc.
Just started using the UK version of 8.1 after getting use to the drag a copy by just toggling the command key (Mac v) in version 8.0. However in version 8.1 it only works by using the alt key. Worse than that though it doesn't seem to work at all us...
  • 6401 Views
  • 3 replies
  • 0 likes
Line Caps
Is it possible to change the rounded end of lines to be square, ie. as in CorelDraw?
  • 4948 Views
  • 3 replies
  • 0 likes
ArchiCAD for construction purposes??
Hi all! I just joined this forum and I work at a large civil engineering company in Sweden (www.ncc.se). I have been working with ArchiCAD for several years by now mostly in R&D projects since we are deeply stuck in the 2D Autocad mud. I wonder if th...
  • 16705 Views
  • 13 replies
  • 0 likes
how to plot A1 LANDSCAPE on an A0 roll feed
how to plot A1 landscape on an A0 roll feed and not waste paper. . . see attached PDF 'how-to' that took much longer to figure out than it seems! this was worked out for our practice back in the OS9/archiCAD 6.5 days, and for an HP330 plotter, but th...
Djordje by Mentor
  • 9542 Views
  • 0 replies
  • 0 likes
