Document & Visualize forum
Forum Posts
CineRender Scene preset loses name
Hi, I'm in the process of setting up a series of rendering presets for our practice. I've saved a few out as the *.renderingscene file type, with the final name and number so staff can select them easily (on the left in the attached screengrab) When ...
Zone stamp in 3d
HI guys I search for an answer to this but I could-t find it. is there a way to display the zone stamp in the 3d window along with the zone ? thanks in advance best Luis
Anonymous by Not applicable
  • 1147 Views
  • 1 replies
  • 0 likes
Duplicate page layout(s) and subset
For some time now I have attempted several times to duplicate a page layout or a complete subset. but there is no option do do so, it seems such a fundamental thing to be able to do. I will give you an example: I have a layout book subset for my comp...
  • 8885 Views
  • 6 replies
  • 0 likes
Advice needed re: fonts in BimX Pro
I am about to try out BimX Pro at the same time I am redoing office templates. I would like to standardize on a font that is going to read similarly for everyone who uses the file. Am I doomed to using to using Arial? (which I hate, btw). Are there o...
Override surfaces per view
I am trying to create views showing structure, MEP, and some architectural elements for coordination purposes. I want to color-code each type of element in order to understand how they are interfacing. For example, structure to appear as red, ductwor...
  • 1929 Views
  • 4 replies
  • 0 likes
loaded image texture changes color!
hi everyone! i'm trying to load an Image texture to render a tiled floor. (see attachments) the tiles should have brownish colours but when i use the cinerender to render it changes to greenish gray? in the internal renderer the colours are fine so t...
  • 6148 Views
  • 11 replies
  • 0 likes
