Document & Visualize forum
Forum Posts
Layout shrinking to page in Plotmaker 3
I use Plotmaker 3.0.0 R2 Int for output my drawings to printer. Usually, my layout exceeds page size. So, when I print my layout, Print->Print options...->Shrink each layout to page setings changes output scale of my drawing. It is vary unusable for ...
Anonymous by Not applicable
  • 5370 Views
  • 3 replies
  • 0 likes
Material in rendering
I tried to apply a material, which was a ceramic on a column. This column is repetitive on a module. I always find thet the ceramic tiles shift from one column to another, cause i think it related to an origine like fills. I don't know if there is a ...
  • 7387 Views
  • 4 replies
  • 0 likes
ArchiLumos
Anyone would like to share their experience with this rendering/lighting products for archicad? http://www.graphisoft.co.jp/products/ArchiCAD/ArchiLumos.htm
  • 34555 Views
  • 30 replies
  • 0 likes
Scale in PM & AC
It has been said to draw in your normal scale in AC such as 1/4" then to change your output scale in PM as you need it for the different size drawings such as D or tabloid. This seems fine until you update a drawing, then PM reverts the AC drawing ba...
  • 3937 Views
  • 1 replies
  • 0 likes
Hairline Printing in Plotmaker
I thought there was a way to get hairline printing output from setting the output to hairlines in Plotmaker. The plotmaker option I find says its a screen only control not a printing control. I finally managed to get my first cd book together in plot...
  • 10598 Views
  • 6 replies
  • 0 likes
Artlantis Billboard file problem.
Hi there. Has anyone visited the ArchiRADAR site lately and downloaded the free set of billboards made available by Mr. Natalino Paolo Arnò? If so, could you please tell me how to get the file to work in Artlantis?? It downloads 31 billboards as a si...
  • 9400 Views
  • 6 replies
  • 0 likes
Light Sources 70
Spotlight Ceilign 70- I can't change the vertical angle of the spotlights . so the angle of luminance falls onto the middle of the sign panel. Strip lamp 70- what is the difference between brightener and intensity? I've to switch the brightener to OF...
  • 17342 Views
  • 11 replies
  • 0 likes
Printing/plotting white fill difference
We are using Archicad R3V3 (awaiting 8.1....) on Mac G5's, with Kip Star Print Plotters. We notice that when we plot elevations with areas masked out with color 91 solid-fills, they do not mask out anything. When we print, it works fine. The problem ...
TomWaltz by Newcomer
  • 5513 Views
  • 2 replies
  • 0 likes
VR Scenes panorama camera views
We are making vr scenes and have about 5 camera linked. When we are in the movie and jump to the next camera position I'm facing in a direction I don't want to start looking at because I think it would confuse people looking at the movie. Is there a ...
  • 8123 Views
  • 4 replies
  • 0 likes
