Document & Visualize forum
Forum Posts
Fill show incorrectly
I have been fighting Archicad for the last few weeks and think that it is winning! I used the fill tools to add 300x300mm tile fill on a working drawing I am doing. Used before in AC23 it showed correctly. Used here in AC24 it simply doesn't. Two iss...
KeesW by Advocate
  • 575 Views
  • 3 replies
  • 0 likes
Newbie to Rendering
Hi all, I work for a Planning Consultancy so most of our project deliverables are 2d black and white floor plans and elevations. This is the main requirement for planning in the UK but I want to be able to show our schemes in more visual ways. I have...
Rotate Drawing Title on sheet
(Is there a limit to the amount of questions I can post per day?..... ) My drawing is rotated 270° to fit onto my sheet. The title of the drawing is now to the left of the sheet. Can I change that so the title is at the bottom of the drawing?
Keynotes using the change tool
After searching high and low for a workable keynote creation method in archicad, exasperated, I almost gave up. My last resort has been to use the change manager to add keynotes to my construction set of drawings, including elevations, sections and d...
Anonymous by Not applicable
  • 1251 Views
  • 6 replies
  • 0 likes
Resolved! North symbol: following project north
I seem to have 2 questions concerning project north. First: Placing a north symbol in the project map seems to work fine and correspond to the "follow project north" setting. This also works fine when the north symbol is placed on a Master layout. Bu...
Resolved! elevation markers don't have second line
Hello, for elevation marker in the floor plan, - one elevation line has "second line" which control the view distance, but - the orthers don't have and unable to adjust the view distance Please advice how to set the second lines back Thanks
  • 418 Views
  • 2 replies
  • 0 likes
Rendering stuck at 0,0%
Hi, I have been having an issue when rendering with MAXON CineRender, where rendering gets stuck at 0,0% after counting. I have been waiting several hours for something to happen, but it stays at 0,0%. It only gets to this very pixelated image (scree...
  • 1367 Views
  • 3 replies
  • 0 likes
