Document & Visualize forum
Forum Posts
Resolved! Exploring in 3D, Model disappears as i navigate.
This happened all of the sudden but when i explore in 3D, the model disappears wherever I go as if there is a bubble the camera is in and nothing within that bubble is visible. When I walk around the model just disappears! If I back up the model reap...
Miner by Contributor
  • 712 Views
  • 3 replies
  • 0 likes
Resolved! View Map & Layout rotation are not the same
I have an orientation and zoom saved for my View Map plans.So when I open my View Map, it opens to the correct orientation. But when I place the views onto my Layout, the orientation is different, even though the orientation is set to 0deg. Anybody c...
Johann_P by Advocate
  • 868 Views
  • 12 replies
  • 0 likes
Drawing Manager to purge unused views
I'm trying to use the Drawing Manager to find drawings in the View Map that isn't on a layout, and to find drawings in the Project Map that isn't linked to the View Map. I'm not sure how to do that.Is the Drawing Manager the best way?I cant seem to u...
Dimensions- Project Preferences
I can not seem to add any new Dimension preferences . Every time i start modifying a dimension preferences instead of converting to "custom" it jumps to my preference called "1/64"the "1/64" I believe is the issue I am assuming it is because of the "...
Jen1 by Participant
  • 672 Views
  • 14 replies
  • 0 likes
Teamwork Recovery File Issue
Hi, This is the first time we are encounter this issue. Here's the screenshot.We tried all options but this message pops up every time we try to save or send/receive. The project is also stuck right but without any loading bar anywhere. We're a bit l...
