Document & Visualize forum
Forum Posts
How to change Altname variable?
Hello all, I'm looking for changing the Altname variable we found when we set "Sea level" in the Level dimension custom text. I've got always the "Altitude" name and I'd like to set another one...
Stair cover fill
I'm trying to figure out how to display a cover fill on a stair to represent the finish, just as I would with a slab etc. WIth a slab, you can use the fill of the surface, so if the surface / building material changes, the fill changes too. I can't f...
Bruce by Advocate
  • 530 Views
  • 4 replies
  • 0 likes
Expressions for layouts and drawings
Hi everyone I'm new to expressions in ArchiCAD, and I was hoping to create a conditional expression for the 'scale' portion of our title block. Essentially, I would like it to show the scale of the drawings on the sheet if they are all the same, and ...
jrmrt by Contributor
  • 396 Views
  • 1 replies
  • 0 likes
GO?
Hi everyone! In electric plan, I want to highlight electric symbols/electric related lines and have floor plan and the rest in back ground/pale grey. I tried to make new GO combination but it shows everything except text in grey, attached. Thanks.
Anonymous by Not applicable
  • 676 Views
  • 1 replies
  • 0 likes
2x2 ceiling fill printing problem
I'm not sure why when I print out my reflected ceiling plan, my 2x2 ceiling fill comes out funny--- has anyone has this problem and how did you solve it? Even if i changed my pen weight from .05mm to .15mm, it does not make a difference. attached are...
dhnguyen by Contributor
  • 1323 Views
  • 12 replies
  • 0 likes
Resolved! Twinmotion DirectLink failing to update project
So, I have this complex project: 200MB, total polycount 7million; 6 Hotlink Modules for multiple parts of it with other nested ones, etc. Despite all this I got ArchiCAD to smoothly sync various times the project with the scene as the workflow progre...
