Design forum
Forum Posts
Resolved! Door surfaces
Hi, When amending door surfaces, I am having trouble in getting the model to read as glass door with timber or metal leaf framing. Either the door will read as a glass leaf with no top, bottom or mid rails and no styles; or it will read as a solid ma...
CharlieS by Contributor
  • 69 Views
  • 3 replies
  • 0 likes
Resolved! Layers: Objects are transparent it appears
I am having an issue in plan view with layers showing through each other. I have a floor that is raised above another that by a couple feet and the lower of the two is showing its outline. I can't seem to get the layers to hide one another when overl...
Trim function issue
Wondering if anyone can advise. When using the trim tool between the roof plane and wall, I end up with the wall showing on the surface plane of the outer roof. Attached image shows the issue. Why would this occur? 
Modelling fully parametric columns
Hi All,I wanted to ask whether it is possible to model columns which has a lot of joints, joist elements and so - I am able to model everything separately, but the question is whether it is possible to model all of those (see attached screenshots) as...
CURSOR
My Archicad 26 default cursor is the syringe resulting in the first click being a reloading of attributes. I manually convert to the Arrow in Preferences but the syringe automatically returns. How can the Arrow Tool be locked as the default cursor?
110958 by Participant
  • 70 Views
  • 3 replies
  • 0 likes
How to join slabs in cross section?
1. subtractI thought no.2. I have to move to the same point with two slabs to be combined.3. Is this normal?Or am I doing something wrong?I would like to know the exact way to combine.What is this phenomenon?
LeeJaeYoung_2-1664022540948.png LeeJaeYoung_3-1664022824806.png LeeJaeYoung_4-1664022880538.png LeeJaeYoung_5-1664022910913.png
Best way to develop a wall object
Hello, I needed to develop a wall block where there is a need for a metallic profile that is automatically distributedThis wall block has specific dimensions like 60 centimeters high and 23 centimeters wide.I can develop this wall with a complex prof...
Lucas343 by Contributor
  • 117 Views
  • 4 replies
  • 0 likes
Adding favorite from linked library
Hello, I have a document with a external folder in the Libraries in Project. The problem I have is that when one of those objects are placed in the drawing and saved as favorites, they become part of the embedded library and if we update any of the g...
jc4d by Advocate
  • 43 Views
  • 1 replies
  • 0 likes
