Document & Visualize forum
Forum Posts
Automatic Stairs Tread Number Labelling
Hi, the stairs of a 5-story building on each floor has a continuous numbering on plan, starting from number 1 up to number 92. So the first tread on first floor has a number 18 and on the second floor 37 etc. In sections using the command "Label Comp...
Takis by Enthusiast
  • 392 Views
  • 1 replies
  • 0 likes
Copy and paste text changes size with zoom in-out
Hi, this problem refers to Archicad 23 & 22. Steps to reproduce the problem: 1. Write a text. 2. Double click to edit text and copy part or all of the text. 3. Click out of the text to exit edit mode. 4. Viewing the text or other text anywhere, scrol...
Takis by Enthusiast
  • 778 Views
  • 4 replies
  • 0 likes
Expressions in Auto Text Labels?
Is it possible to write an expression in an auto text label so that the resulting text is dependent on the object it is applied to? I am trying to create a wall tag that includes both the wall rating and the composite name of an element. I run into 2...
3D Printing ArchiCAD Models
Just wanted to share my first ArchiCAD Model print. Using personal CR10S Pro and PLA. Very little prep time required, thanks to ArchiCAD's 'Filter Elements'. I had this print out on Friday, as I was working on another project's CD set. If you have a ...
Anonymous by Not applicable
  • 1614 Views
  • 2 replies
  • 0 likes
Detail Workflow
Hi, I'm trying to make my workflow more productive creating lists of details as objects, but it seems that this way is not as good as I wish, objects doesn't permit easy edition. So my question is if does exist some way of create a list of details to...
  • 1672 Views
  • 14 replies
  • 0 likes
3D view, grey model with colour mechanical
Hello I am trying to demonstrate my mechanical and plumbing system, I would like to make a full grey model transparent, not wireframe, and have just the plumbing in colour and then one for the mechanical. I tried making different pensets, but when in...
Foti by Enthusiast
  • 1701 Views
  • 13 replies
  • 0 likes
AC23 door & window labels
Does anybody know where the setting to turn off or "hide marker on plan" for door & window labels has been hidden? It used to be under: Marker symbol & text >Marker geometry in AC22
  • 569 Views
  • 4 replies
  • 0 likes
Rendering not coming properly
Hi, I have completed the model and applied the materials, but when I do the render, rendering is not coming properly. I have adjusted the camera, sun position and all. What could be the issue? Please anyone help me in this. Thank you, Hema
  • 1968 Views
  • 4 replies
  • 0 likes
window door demo mark
in version 23, what happened to the control for putting a big X over a door or window to be demolished. Can't find it any more in renovation filter controls. thanks Tom
