Eaves ending
Hello, I have been trying to find if there is an easy way to have the roof contour (the red line), by now i am doing it using SEO but maybe there is a way i don't know. Thanks
Am attempting to open accessories for a roof object. Accessories are shown as loaded in the Add-on manager, but when I select roof and try to get to the accessories, dialogue box indicates that something needs to be loaded as a library. Seems odd.......
Hi guys, I'm contacting with you because apparently if you don't have a maintenance contract, Abvent doesn't allow us to ask questions... we have a couple of licenses at the office, archicad 22 included. So the question concerns some serious challeng...
Hi! I made a sheet index in an AC20 file that I migrated to AC22. In AC20 the sheets weren't ordered (no little arrow next to fields) so their order followed the folder tree. eg: - Sections - Elevations - Details In AC22 they are in alphabetical orde...
Hello!) I need to create new accessory element for the wall. Where I can get guide about accesories elements creating ? Thank You.
i have written my first GDL script to create a custom architrave for windows and balcony doors. Its working so far but i would like somehow to select windows or doors and apply it like an accessory instead of doing it by hand. Is that possible?
Hi guys, First of all, I have been reading the posts on this blog for a long time and I thank you all for the many times you have helped. Most of the times I haven't participated due to redundancy, but this time I feel compelled to adress this issue ...
It happens really frequently too. I'll go about my business, orbiting and panning with the middle mouse button + shift, and then suddenly, i'm teleported to the "restore view" view, in the model space, and i have to find my way back to where i were. ...
I have the parameter as array of the 10 text strings - MyStrArray I need to edit any of elements of the array. For example - first element (MyStrArray[1]). I try to write in user interface secrion: UI_INFIELD MyStrArray[1], ... Not work UI_INFIELD "M...
I want to share my project with someone with a full license, but i don't want him to have the watermark on the project when he's working on it. Is it possible to somehow use his license on my own PC, and then convert my EDU file to a normal file?
User | Count |
27 | |
17 | |
5 | |
5 | |
5 |
