Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9131 Views
  • 127 replies
  • 18 likes
Resolved! CONC. Column No Outline?
Hi,I copied a series of Concrete columns, for some reason, all the copied columns have no Outline in Section I've looked at the pen & fill properties, but I can't see a difference btw them. The columns are all aligned across section. Please see attac...
cadsph by Enthusiast
  • 242 Views
  • 2 replies
  • 0 likes
Resolved! Wall surface not joining with railing surface
Hi all, i've recenetly changed to using the railing tool when drawing nib walls up stairs (way easier/faster than trimming the wall with a piece of roof imo) The wall below is the same surface as the railing tool but they are not seamless in 3d. Ther...
tomyg by Booster
  • 330 Views
  • 4 replies
  • 0 likes
Custom window reveal materials
I've made some custom windows but when I place them and assign, say, a 30mm reveal, the reveal material doesn't match the exterior/interior wall materials as with the standard windows Is there a setting I've missed or is this a limitation? If limitat...
JohnJay by Expert
  • 240 Views
  • 3 replies
  • 0 likes
Resolved! Save object as object?
I want to create some wet area objects with additional hotspots for use on a slab penetration plan. I don't want to modify the standard Archicad library objects so I will to create a folder of renamed copies of the objects that I can then modify and ...
Resolved! missing object AC 25
hey allso im having a problem with a missing object in Archicad which i cant find anywhere. after some digging it seems that its a file from AC 11 library. i found AC 11 library and loaded it and no more missing object but when i open the object in o...
ahmad525 by Contributor
  • 355 Views
  • 2 replies
  • 0 likes
