Visualization
Render your model with built-in or 3rd-party solutions
Articles
When rendering interior scenes with Redshift in Archicad, ceiling lights may appear as black rectangles instead of evenly glowing panels. This issue is common in interiors with ceiling grids and diffused lighting panels and can make the visualization look artificial and dist...
  • 263 Views
  • 0 likes
  • 0 comments
This article introduces a streamlined technique to showcase a project’s real-world context in Archicad, using a custom skydome object and a 360° site photo. It is intended for Archicad users who want a realistic site background in 3D and BIMx without detailed context modelin...
  • 450 Views
  • 1 likes
  • 0 comments
Sun Study in Archicad is more than a presentation tool; it’s a fast and insightful way to test and validate design ideas. For architectural designers or students familiar with Archicad modelling, this feature provides immediate visual feedback on how sunlight interacts with ...
  • 1550 Views
  • 3 likes
  • 0 comments
Exploded diagrams are a powerful way to present floor layouts, zoning, and structure in 3D, all within Archicad. Here is a simple workflow to create them from a single model view. Set up the 3D view Start in your 3D Projection Settings and switch to an isometric (axonometric...
  • 1720 Views
  • 0 likes
  • 0 comments
With the physically based 3D engine in Archicad, you can display more realistic visualizations directly in the 3D window, without having to separately generate a rendered image. Physically Based Rendering ContoursProcedural SkyImproved Ambient OcclusionShadow MappingAutomati...
  • 24950 Views
  • 1 likes
  • 0 comments
Creating stunning building elevations can be the key to selling your project to clients. Archicad offers powerful tools and features to enhance your elevations, making them more professional and visually appealing. Here are some tips to take your presentations to the next le...
  • 4504 Views
  • 1 likes
  • 0 comments
Ready to enhance your renderings? Let's try the shadow casting feature in Archicad to bring your scenes to life. By adding depth and realism, this feature can transform your designs into life-like renderings. This will help you improve your designs. Add a meaningful descript...
  • 3244 Views
  • 2 likes
  • 0 comments
Visual perspective section in Archicad - blue design Enhance your design presentations with a visual perspective section that helps your clients clearly understand your vision. This tip is from the Create Engaging Drawings with Archicad course, offered through the New to Arc...
  • 2928 Views
  • 1 likes
  • 0 comments
AI Visualiser is a powerful tool that generates visuals to inspire your interior design concepts. To get the best results, craft the perfect prompt! Follow this recipe! Set Your View Adjust your view to the best angle. Open the AI Visualizer Palette (Window > Palettes > AI V...
  • 2712 Views
  • 1 likes
  • 0 comments
Want to give your floor plans a clean, modern look? With Archicad's Graphic Overrides, you can easily customize the appearance of your elements based on certain rules. Follow these steps to achieve a minimalist design for your floor plans! Create a Graphic Override Combinati...
  • 2788 Views
  • 2 likes
  • 0 comments
Our solution to address the intricate requirements of visualization is to offer a versatile and adaptable set of tools. Read more about the rest of the spectrum of our offerings here. One of the items that we dwell on in this toolkit is AI Visualizer. This article is based o...
  • 19239 Views
  • 5 likes
  • 0 comments
In the fast-paced world of interior design, leveraging advanced tools is essential for efficiency and creativity. Archicad users can now benefit from the AI Visualizer, a cutting-edge tool that streamlines the design process and enhances visualization capabilities. In this a...
  • 7520 Views
  • 12 likes
  • 0 comments
This article below will guide you through the uninstallation process of the Legacy AI Visualizer Add-on for Archicad 27 on Windows and MacOS. The Archicad AI Visualizer is our AI-driven image generation tool. Powered by Stable Diffusion, you can use it to create impressive, ...
  • 3973 Views
  • 3 likes
  • 0 comments
Table of Content What type of license do I need to use AI Visualizer in the cloud?End of update and support for the legacy, experimental version of the AI VisualizerBefore installationWhat are the minimum system requirements for using the Add-on?What types of GPUs are compat...
  • 11010 Views
  • 4 likes
  • 0 comments
Table of Content CinerenderBasic settingsRedshiftRedshift Renderer Integration in ArchicadIntroducing Physically Based Rendering in Archicad 3D Views (Experimental Feature)TwinmotionDirect LinkHow to install TwinmotionEnscapeInstall Enscape paletteArchicad-Enscape Workflow A...
  • 11566 Views
  • 2 likes
  • 0 comments
The Additional Surface Catalog needed an update Our users’ essential wish was to update the Additional Surface Catalog. The previous catalog did not fully support the new rendering capabilities within Archicad with the default settings, which required more manual workarounds...
  • 23649 Views
  • 6 likes
  • 0 comments
CineRender R14 has an error sometimes when rendering bitmap images, even with the standard scenes – the transparent rectangle is shown faded around the image. Usually this goes away just as randomly as it came by next time you launch Archicad, but there is also a workaround ...
  • 5489 Views
  • 0 likes
  • 0 comments
Redshift is currently included as a Technology Preview with a few limitations in Archicad 25. Nevertheless, it brings significant benefits in terms of performance compared to Cinerender. At the current stage of development, the following phenomena can be experienced when usi...
  • 31571 Views
  • 7 likes
  • 0 comments
What is Twinmotion? It is a cutting-edge, real-time rendering software developed by Epic Games perfect for architectural visualization. Read more about it here. Archicad full license owners with an active SSA (Software Service Agreement) can acquire a Twinmotion 2021 license...
  • 35555 Views
  • 5 likes
  • 0 comments
Surface Textures on Section/Elevation/Interior Elevation Views Limitations on graphic representation tools require time-consuming workarounds and the help of external software that breaks the BIM workflow. In previous Archicad versions, displaying hi-res surfaces on 2D views...
  • 11379 Views
  • 6 likes
  • 0 comments
Image courtesy of Twinmotion Create high-end visualizations while working on your BIM project, enabling informed design decisions and compelling client presentations. Recommended for architects, interior designers, urban planners and landscaping professionals to easily produ...
  • 71089 Views
  • 1 likes
  • 0 comments
I think we can all agree: nothing is more important than visualizing architectural projects in photorealistic quality. Easy job, isn’t it? You just have to tediously optimize your 3D model, export, import, numerically set a myriad of rendering parameters for camera, sky, lig...
  • 7301 Views
  • 1 likes
  • 0 comments
Virtual Reality (VR) technology is becoming an essential part of the project and the design process in the AEC industry. VR enables all audiences to perceive spaces in the easiest way. It is a good tool for communicating the design to clients and also a way to collaborate wi...
  • 28463 Views
  • 5 likes
  • 0 comments
In Archicad 22 the Cinerender engine introduced the Spherical Camera, making it possible to create 360° renders. What can you use it for? As embedded pictures on websites, combined with BIMx Webviewer's functions, this can become a powerful tool of representation. Also, most...
  • 6817 Views
  • 2 likes
  • 0 comments
Sometimes the best tool to represent the building is a perspective section, allowing an insight into building spaces. We need to use a 3D cut, a 3D document and some simple Model Display settings to do get this right away. Step 1: Create Model In our example we are working w...
  • 22524 Views
  • 1 likes
  • 0 comments
Affected version: all versions | Severity: workaround applicable Issue In case there is a mesh with grass surface, the 3D grass doesn’t appear on the mesh in the rendered image, when there are more than 100 million blades; however, it is set in the Surface settings and in th...
  • 6224 Views
  • 1 likes
  • 0 comments
Users with an active SSA (Software Service Agreement) may download an exclusive set of 500+ additional surfaces, which are not included with the standard Archicad library. Please follow these steps to download and load the catalog to your project: For Standalone Projects (.p...
  • 35153 Views
  • 5 likes
  • 0 comments
With this feature, you can display the elements in any model view according to a customised graphical definition, to easily communicate the design to everyone involved. Use Graphic Overrides to create thematic drawings in a semi-automatic way. You don’t have to spend time on...
  • 7887 Views
  • 2 likes
  • 0 comments
One-Point perspective In ARCHICAD we have an option to look to perpendicular of a clicked surface. You can find this option under View/3D Navigation Extras/Look to Perpendicular of Clicked Surface and will be active if you are in a 3D view. Use the "Look to Perpendicular of ...
  • 8744 Views
  • 0 likes
  • 0 comments
Align View is an option to set your ARCHICAD model rendering to an imported background photo. It enables the architect to automatically reconstruct the position of a camera in the interior or on the street from a picture taken of it. This feature can be used both for inserti...
  • 13889 Views
  • 1 likes
  • 0 comments
To introduce your 3D model as an image, Archicad contains more integrated Rendering Engines. This article details the available settings in the PhotoRendering settings window when using the Sketch engine and how to create the sketch look on your floorplans as well. Sketch Re...
  • 20735 Views
  • 0 likes
  • 0 comments
For visualising architectural concepts or a design process the usage of animated GIFs is getting more and more popular. No wonder, with a sequence of images you can provide a very clear explanation of your project's fundamental idea. The message of GIFs can't be missed, it i...
  • 7162 Views
  • 1 likes
  • 0 comments
The Tech Tip July 2002 winner, BertNijs , from Belgium found a way to show Floor Plans in the 3D Window inspired Karl Ottenstein to find a way to create a sketchy look of 2D drawings of ARCHICAD (Floor Plans, Section-Elevation Windows etc.) The idea came after a user wanted ...
  • 6165 Views
  • 0 likes
  • 0 comments
Artlantis is a popular and easy-to-use rendering application for ARCHICAD and other CAD software. It is developed by the French software company Abvent Among the features of Artlantis are a real-time preview window that shows radiosity (illumination), textures, shadows, refl...
  • 7127 Views
  • 0 likes
  • 0 comments
