Design forum
Forum Posts
Chinese character imput (text)
Hi, We have a project in China, and (of course) we have to write in Simplified Chinese... In AC7, OS 10.2, everything is "out of the box" simple, but for some reason, AC8 v3 doesn't like asian characters, whenever I select the language from the OS ba...
Anonymous by Not applicable
  • 5441 Views
  • 3 replies
  • 0 likes
How can I show a window correctly with a brick veneer?
Maybe I am missing something, but how does one properly show a window with brick veneer? My composite wall has a 4" brick exterior veneer, air space, 1/2" sheathing, 2x4 stud cavity, and 1/2" drywall. The window pastes itself with the brick moldings ...
  • 4234 Views
  • 5 replies
  • 0 likes
How to change materials in C4D
Or if you want to work solely in Cinema to make the changes, I have made an 8 step pdf that explains what to do. Selection Sets.pdf
  • 6184 Views
  • 1 replies
  • 0 likes
Tangent to two circles - S version
~/archiben wrote:... what about the "S figure" version Thankfully that's easier ?! ... 1. Construct the cocentric axis as before (line between the two circle centres) 2. Copy-rotate this line around both ends/centres to generate the perpendiculars (t...
  • 4966 Views
  • 0 replies
  • 0 likes
While we're waiting for the Magic-Addon package, including the option to click on two arcs and automatically create the tangent, we can pay some humble homage to the Greeks... Draw the two circles (or arcs) 1a) From the centres of each circle constru...
  • 5671 Views
  • 0 replies
  • 0 likes
Need help drawing complex wall segment
I am new to ArchiCAD. I'd like to model a composite wall segment consisting of three layers... basically, 2 concrete walls with an insulation layer between. But there's another twist. The concrete segments are "keyed" so that they lock together. Wall...
  • 10596 Views
  • 6 replies
  • 0 likes
Stretchy angle hotspots in 2D
I am a tad confused about how the angled 2D moving hotspots work. After reading the manual about 100 times and randomly putting in numbers i got them to work but I have a few questions. 1. in the manual it states you need four points then they only s...
  • 5968 Views
  • 3 replies
  • 0 likes
Showing dashed in section what's beyond the cut
Glad that did the trick, Michele. The tip that I learned this from was on the old list on October 10 - thanks again Djordje and Link - this belongs in the Tips section: http://www.escribe.com/software/archicadtalk/m34966.html http://www.escribe.com/s...
Screening
Does anyone have any ideas/suggestions for simulating screening in elevation view? Partially hide what's behind? Thanks, Steve
Can't Create Line Tangent To Two Circles
In 2D, how do I create a line that is tangent to two circles? I can get the second endpoint tangent to the second circle, then reposition the first endpoint tangent to the first circle, but this makes the second point's angle different, therefore it ...
  • 17046 Views
  • 18 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
