Project data & BIM
Read articles about BIM-based management of attributes, schedules, templates, favorites, hotlinks, projects in general, quality assurance, etc.
Articles
Global Settings Affecting Zone Data and Display
Options->Project Preferences->Zones Dialog Zone Instance Setting affecting Zone Data Zone Settings Dialog –> Name and Positioning panel Zone Settings->Area Calculation panel Other Element’s Instance Setting affecting Zone Data Wall Settings Dialog->G...
wp-content_uploads_2011_07_01-project-pref.png wp-content_uploads_2011_07_02-zone-settings.png wp-content_uploads_2011_07_03-zone-settings.png wp-content_uploads_2011_07_04-wall-settings.png
Scheduling Component Data of Complex Profile Structures
Interactive Schedules allow you to list the individual components of Composite and Complex Profile structures. When creating a new Interactive Schedule scheme, you can select whether the scheme should list information on Construction Elements, Compon...
wp-content_uploads_2011_10_01_new-schedule-1.png wp-content_uploads_2011_10_02_components-1024x701.png wp-content_uploads_2016_11_05_schedules.png wp-content_uploads_2016_11_06_all.png
  • 5133 Views
  • 0 comments
  • 0 likes
How to list the Wall Surface
In ARCHICAD listing/scheduling the Wall Surface is not possible if the Zone's body was modified with a Solid Element Operation. Until the correction is implemented there is a possible workaround. Basic idea Instead of the Zone we will list a Morph, c...
wp-content_uploads_2016_10_02-1-1024x682.png wp-content_uploads_2016_10_03-1.png wp-content_uploads_2016_10_06b-1024x345.png wp-content_uploads_2016_10_08.png
Tab Based Navigation - Troubleshooting Guide
This Troubleshooting guide will show you the new special functions of the Tab Based Navigation. If you want to learn how this Navigation works detailed please go to the ARCHICAD Reference Guide Tab Bar section. As of ARCHICAD 20, when you switch betw...
wp-content_uploads_2016_06_NamesOntheTAB.png wp-content_uploads_2016_06_VPNamesOntheTAB.png wp-content_uploads_2016_06_ExclInNamesOntheTAB.png wp-content_uploads_2016_06_ContextMenuofTABs.png
mtron Graphisoft | Graphisoft
  • 3790 Views
  • 0 comments
  • 0 likes
Save and Apply Favorite Settings
Most architectural firms have a standard set of element settings they use repeatedly, in multiple projects. These may include standard Walls, Doors/Windows, Composite Slabs. This article describes how to save these standard element settings for later...
wp-content_uploads_archicadwiki_saveandapplyfavoritesettings--favorites-01.png wp-content_uploads_archicadwiki_saveandapplyfavoritesettings--favorites-02.png wp-content_uploads_2011_06_01b.png wp-content_uploads_2011_06_02.png
  • 4892 Views
  • 0 comments
  • 1 likes
SQL Queries
"(...) Someone asked me privately if there was a way to extract all of the layer settings for every layer combination in order to document all of the Layer combinations in an external program such as Excel or Access." This tip is an example of using ...
wp-content_uploads_2016_06_01.png wp-content_uploads_2016_06_02-1024x692.png wp-content_uploads_2016_06_03.png wp-content_uploads_2012_01_show-data-structure.png
Work Environment - Troubleshooting Guide
The External Content Menu is missing from the File menu in ARCHICAD 19 Solo edition Issue The External Content menu is missing from the File menu therefore the Place External Drawing command and the Drawing Manager menu is also missing from the defau...
wp-content_uploads_2015_07_External-content-missing.png wp-content_uploads_2015_07_Navigator-Drawing-Manager.png wp-content_uploads_2015_07_place-external-drawing-WE.png wp-content_uploads_archicadwiki_bugs-missingtooltips--tooltip.png
Background Updating
Background Updating Background Updating uses idle processor capacity to generate the 3D model and its associated BIM data for open windows and tabs. Before AC19: When switching to another open window, all model generation for that window would begin ...
Attribute Manager
The Attribute Manager (Options menu) is a handy tool to create and manage the Company-standards in your Archicad projects. Its commands allow you to copy (append, overwrite) attributes (Layers, Layer Combinations, Pens & Colors, Line Types, Fill Type...
Screen Shot 2022-12-01 at 11.38.33.png Screen Shot 2022-12-01 at 11.36.49.png
  • 5245 Views
  • 0 comments
  • 0 likes
Top 12 ARCHICAD Commands You Should Use all the Time
Would you like to work faster and more efficiently in ARCHICAD? We have collected 12 lesser known shortcuts in ARCHICAD International version that can ease your daily workflow: Highlight Toggle Shortcut: TAB Have you ever wanted to select a Zone inst...
wp-content_uploads_archicadwiki_topcommands--quickselection.png wp-content_uploads_archicadwiki_topcommands--quickselection01.png wp-content_uploads_archicadwiki_topcommands--forceguidelines.png wp-content_uploads_archicadwiki_topcommands--hideguidelines.png
Replace Attributes by File: Automate Attribute Migration
If you are migrating multiple similar project files to Archicad 17 , the Replace Attributes by File function can help you speed up the migration process: it automates the Delete and Replace attributes function, instead of you having to issue repetiti...
Info_18x18.png wp-content_uploads_archicadwiki_attributemigration--1.png wp-content_uploads_archicadwiki_attributemigration--att2.png wp-content_uploads_archicadwiki_attributemigration--att3.png
  • 5166 Views
  • 0 comments
  • 1 likes
Template Files
See also: Template Files in ARCHICAD Help A template is a read-only project file with extension tpl. Why should I create my own template Templates are intended to cut down or eliminate the time to create a new project by reducing the repetitive task ...
wp-content_uploads_archicadwiki_templatefiles--save.png wp-content_uploads_archicadwiki_templatefiles--open.png
Layer Extras
Updating Views and Layer Combinations via the Context Menu – by Link Ellis, Worldwide Consultant "If I am working along in a view and decided that I want to turn a couple layers off so I click and hide them through right click, or through the palette...
wp-content_uploads_archicadwiki_updatingviewsandlayercombinations--hidelayerfromcontextmenuuj.png wp-content_uploads_archicadwiki_updatingviewsandlayercombinations--sortedalllayersandselectedlayercombotochangeuj.png
Cost Calculation Using Interactive Schedules
In order to estimate the costs in a project please take the following steps. This example will calculate the individual and total costs of the four doors (two of which are identical) in the plan below. Step 1: Set Cost Values for Elements in the Proj...
wp-content_uploads_archicadwiki_costcalculation--01.png wp-content_uploads_archicadwiki_costcalculation--02.png wp-content_uploads_archicadwiki_costcalculation--03.png wp-content_uploads_archicadwiki_costcalculation--04.png
Building a Pen Chart with SQL
"(...) I'm imagining a utility object that will automatically build a pen chart in the floor plan window with a user defined array of squares and accompanying text label for each pen. It would be a great help when introducing new coworkers to our pen...
wp-content_uploads_archicadwiki_penchartwithsql--01.png wp-content_uploads_archicadwiki_penchartwithsql--02.png wp-content_uploads_archicadwiki_penchartwithsql--03.png wp-content_uploads_archicadwiki_penchartwithsql--04.png
Typical 3D and 2D Speed Problems - Troubleshooting Guide
3D Summary of Typical problems Too many polygons count number of polygons with PolyCounter tool (Help menu > ARCHICAD [version] Downloads) to determine polygon count find objects with too many polygons watch out for objects coming from 3DS, C4D forma...
wp-content_uploads_archicadwiki_2dspeed--feedback.png wp-content_uploads_archicadwiki_2dspeed--navioptions.png wp-content_uploads_archicadwiki_2dspeed--updateoff.png wp-content_uploads_archicadwiki_2dspeed--snappoint.png
Quick Layers Palette
Originally published at Cadalyst, written by Eric Bobrow Principal, Bobrow Consulting Group Editor's note: This tutorial is courtesy of Archicad. Archicad's Quick Layers palette complements the Layer Settings dialog box that allows layers to be turne...
Screen Shot 2022-12-01 at 14.48.31.png Screen Shot 2022-12-01 at 14.49.12.png Screenshot 2022-12-02 at 11.04.37.png wp-content_uploads_archicadwiki_quick-layers-palette--4.jpg
ARCHICAD Office Standards and Templates
This article is written by Eric Bobrow, Principal of Bobrow Consulting Group.Office standards set the graphic appearance and organization of documents produced by a firm. They also play a significant role in promoting consistency, efficiency and usab...
wp-content_uploads_archicadwiki_archicad-office-standards-and-templates--1.jpg wp-content_uploads_archicadwiki_archicad-office-standards-and-templates--2.jpg wp-content_uploads_archicadwiki_archicad-office-standards-and-templates--3.jpg wp-content_uploads_archicadwiki_archicad-office-standards-and-templates--4.jpg
ARCHICAD's Powerful Clone Folders
Originally published at AECBytes: http://aecbytes.com/tipsandtricks/2007/issue24-archicad.html written by Eric Bobrow Principal, Bobrow Consulting Group Within the Navigator View Map, ARCHICAD has a powerful, yet little-known and underutilized featur...
wp-content_uploads_archicadwiki_archicad-s-powerful-clone-folders--1.jpg wp-content_uploads_archicadwiki_archicad-s-powerful-clone-folders--2.jpg wp-content_uploads_archicadwiki_archicad-s-powerful-clone-folders--3.jpg wp-content_uploads_archicadwiki_archicad-s-powerful-clone-folders--4.jpg
Tips to set up Work Environment
At the bottom of the Start Archicad dialog box, you can select your preferred Work Environment profile. Unlike Project settings, Work Environment settings are saved not as part of the project, but in a local folder on your computer. The individual se...
Screen Shot 2022-11-11 at 13.53.34.png Screen Shot 2022-11-11 at 13.55.18.png Screen Shot 2022-11-11 at 14.00.26.png Screen Shot 2022-11-11 at 14.14.45.png
