Archicad versions
Greg Kmethy
Stay in the loop!
Visit our Roadmap for a clear view of our ongoing feature development.
Archicad 28
Design the future with Archicad: design sustainable and better performing buildings with AI, work seamlessly with engineers, build momentum growing your business.
More details
System Requirements here
Release year: 2024
AI Visualizer.svg
AI Visualizer
Library.svg
Global Library
FileFormat.svg
IDS Support
Cloud.svg
Improved point-cloud support in Archicad
Keynote.svg
Keynotes
Onboarding.svg
Quick Tutorials in Archicad 28
Archicad 27
A brand-new design option solution, updated visualization tools, improved project management workflows, and open, multidisciplinary design collaboration make Archicad 27 your best design option.
More details
Release year: 2023
DesignOptions.svg
Enhanced Design Exploration with Design Options
DistanceGuide.svg
Distance Guides
DataTable.svg
Improved Format Options for Interactive Schedules
DEVBrowserWindow.svg
Modern GDL Editor
CloudLicense.svg
New Cloud-based Software Licensing
Handshake.svg
Open BIM Workflow Improvements
Archicad 26
More details
Release year: 2023
Bimx.svg
BIMx: More functional BIMx Web and Desktop Viewers
KitchenCabinet.svg
Enhanced Documentation and Modeling Capabilities for Kitchen Cabinets
AttributeManager.svg
Improved Attribute Management
GearSettings.svg
Library Part Maker Now in All Localized Archicad Versions
BuildingMaterial.svg
New Building Material Property Set for Life Cycle Assessment and Sustainability Calculations
MagnifyingGlass.svg
Search in the Navigator
Archicad 25
Powerful enhancements to design, visualization, documentation, and collaboration capabilities are a direct response to user feedback, making Archicad 25 the most user-driven version to date.
More details
Release year: 2021
Select.svg
Greater Productivity in Archicad with Smart Selection
Library.svg
Library Enhancements
SurveyPoint.svg
Native Survey Point
Skyscraper.svg
Powerful Design Presentations with Archicad
GraphicOverride.svg
Quick Graphical Quality Checks with Archicad
Stairs.svg
 Stair Tool Improvements
Archicad 24
Archicad 24 connects design and delivery teams in a fully ‘open’ BIMcloud environment, powered by advanced collaboration and communication workflows. Seamless and transparent information exchange builds trust among team members, eliminates model duplication and redundant work between architects and engineers.
More details
Release year: 2020
StructuralAnalyticalModel.svg
Integrated Structural Analytical Model
Flag.svg
Issue Management in Archicad
ModelCompare.svg
Model Comparison, Visualizing Model Changes
FileFormat.svg
Project and file management on BIMcloud
Group.svg
Team management on BIMcloud
TargetGroup.svg
Tracking Changes in Teamwork Projects
Earlier versions
Archicad 20
Release year: 2016
Platforms: Mac OS X 10.10, Mac OS X 10.11, Windows 8.1, Windows 10
3DM Import-Export CineRender Engine Upgrade: R16 DWG Improvement
Graphic Overrides for Design Communication  Graphical Favorites IFC Improvements
Improved Library Management Improved Tab-Based Navigation NURBS Definition in GDL
Refreshed UserInterface Two-Point Perspective  User-Defined Elements properties
Archicad 19
Release year: 2015
Platforms: Mac OS X 10.9, Mac OS X 10.10, Windows 7, Window 8, Windows 8.1
Label Tool Enhancement Library Improvements (Simplified Door/Window UI) IFC Import Improvements
Improved Background Processing Interactive Surface Painter  Optimized OpenGL Engine
New Guide Line System PDF Improvements Point Cloud support
Archicad 18
Release year: 2014
Platforms: Mac OS X 10.7, Mac OS X 10.8, Mac OS X 10.9, Windows 7, Windows 8, Windows 8.1
BCF Compatibility for Expanded IFCBased Collaboration BIMcloud Integration DWG Developments
Enhanced Mark-Up Features IFC Quality Improvements Interior Elevation Improvements
Improved Revit 2015 Connection Improved PDF-based data exchange Labeling IFC
Labeling IFC Data Library Improvements New Integrated CineRender Engine
New Objects New Lamps and Light Sources Revision Management Improvements
Reservation and Feedback Changes in Teamwork
Archicad 17
Release year: 2013
Platforms: Mac OS X 10.6, Mac OS X 10.7, Mac OS X 10.8, Windows Vista, Windows 7, Windows 8
3D Cutting Plane Building Material Core-Based Reference Line
Curved Beam Energy Evaluation Improvements Export to STL Format
Floor Plan-Based 3D Document IFC Improvements Integrated Connections with Google Earth and SketchUp
Model-Based Junctions Link Element Height to Stories PDF/A Support
Performance Improvements
Archicad 16
Release year: 2012
Platforms: Mac OS X 10.6, Mac OS X 10.7, Mac OS X 10.8, Windows XP, Windows Vista, Windows 7, Windows 8
Assign Thermal Properties to Archicad Fills  BIM Components Portal Easier Library Part Access
Easy-to-Use Rotate Command Expanded Teamwork Backup Options Expanded Project Info Dialog
Graphical Editing Improved IFC Collaboration Integrated Energy Evaluation
Morph Tool Transform Existing Elements Quick Energy Evaluation Report
Smarter DXF/DWG Data Exchange
Archicad 15
Release year: 2011
Platforms: Mac OS X 10.6, Windows XP, Windows Vista, Windows 7, Windows 8
3D editing plane 3D Guide Lines 64-bit Mac version
Complex Roofs Customer Experience Improvement Program Easy Library Migration
Enhanced Model Connections Fast AutoSave IFC properties as Archicad parameters
Renovation Shell tool Skylights
Archicad 14
Release year: 2010
Platforms: Mac OS X 10.5, 10.6 (Intel only), Windows XP, Windows Vista, Windows 7
64-bit BIM Server for MacOS Expanded Find and Select criteria Dimension prefix and suffix
New interaction in schedules and indexes New offset functionality Open Design Collaboration
Teamwork Travel Pack Site-survey data import Shadows in OpenGL
Streamlined export of schedules to Excel Streamlined library migration and more details on conflicting or missing parts Unlimited skins for composites
Archicad 13
Release year: 2009
Annotated schedules Certain library part parameters now in Model View Options Control of section/elevation boundary (cut) lines
Embedded objects and libraries Improved criteria (filters) for Find & Select and schedules Improved DWG exchange
License borrowing (network license) New TeamWork concept with BIM Server  Oriented view
Ruler, "fit in window" view setting Roof/slab edge material control Soft insulation
Slanted slab edge
Archicad 12
Release year: 2008
Platforms: Mac OS X 10.4, 10.5 (PPC and Intel), Windows XP, Windows Vista
3D Document Bi-directional drawing markers Curtain  Wall tool
Fill enhancements including image fills Improved Hotlink management Multithreading/multicore support
Multipage schedule layouts Nudge/align/distribute elements Partial structure display
Publish to PMK Reveal options for doors/windows
Archicad 11
Release year: 2007
Platforms: Mac OS X 10.4 (PPC and Intel), Windows XP, Windows Vista
Interior Elevation Tool Multistory Hotlinked Modules New Curved Wall Types
Linework Normalization Link Construction Elements to Stories Long File Names Allowed
Pen Sets in Views PDF Export Quantities of Individual Element Components
Section/Elevation Tools Separated Single Undo Queue Uncut Line Types
Virtual Trace Worksheets XREF Layer Separation
Archicad10/ IntelMac Release year: 2006
Platforms: Mac OS X (Intel)
First version for Intel based Mac
Archicad 10
Release year: 2006
Platforms: Mac OS X (PPC), Windows XP
AutoText Creating custom components (e.g., door panels)  Customizable Work Environment
Distorted and gradient fills Enhanced schedules and new project indexes Element snap
Flexible placement of wall openings Floor plan cut plane Guidelines
Integrated layouting including Drawing Tool LCF for libraries Named Pen Sets
New menu structure New 3D Orbit and Explore modes Numeric input via Tracker
On-screen vs model view options Placeable PDF Pre-selection
Profile Editor Project Organizer Shaded sections/elevations
Slanted/Profiled elements Story levels in sections/elevations Tracker
View selected elements in 3D
Archicad 9
Release year: 2004
Platforms: Mac OS X, Windows 2000, Windows XP
Advanced Fill/Line Categories Docking Palettes Improved Pet Palettes
Independent Detail Intelligent AutoSave Library Part Search
LightWorks rendering engine Line Weight Parameter Transfer
Quick Selection Rich Text Section Transparency
Text Rotation Work Environment Customization XREF Dialog
Archicad 8
Released: 2002-2003
Platforms: Mac OS 9/OS X, Windows NT4, Windows 2000, Windows XP
Automatic Clean Intersections at Walls Arrangement of Print Area Editable Library Hotspots
Header/Footer Option for Print Hyperlinks in PDF (Win) Keyboard Shortcut Customization
Layout Book Navigator OpenGL
Print Marquee Solid Element Operations Support QuickTime Image Format
Wall End Tool Window Background Plan
Archicad 7
Release year: 2001
Platforms: Mac OS 8/9/OS X, Windows 98, Windows NT4, Windows 2000, Windows XP
Construction Simulation Element ID Manager Favorites Palette
Freehand Spline Tool Library Browsing Controls Library Manager
Library Status Report Mark-Up Plot Setup
Quick Views in 3D Publisher Reviewer
Section Line Display Skylights Structural Grid
Wall Wizard Zone Stamp Rotation
Archicad 6
Released: 1998-1999
Platforms: Apple Macintosh, Windows 95, Windows NT, Windows 2000
3D Zones Additional Special Snap Points Beam Tool
Boolean Circular Arcs in Dimensioning Composites for Roofs
Custom Label Type Creating Patches Editing in 3D
Editing in 3D Elevation and Gravity Control Ellipse Generation
Explode Extended Find&Select Options Figure Tool
Ghost Story Gravity and Hole Adjustment for Meshes Hotlinked Modules
Magic Wand Mesh Tool More DXF/DWG Conversion Options
New Relative Construction Methods New Snap Points New Wall Types
Resize Roof Generation and Trimming in 3D Rotated Grid System
Round Columns Symbol Hatch Trimming Elements to Roof
Trimming at Intersections Updating Zones Vectorial Hatches and Sun Shadow in Sections/Elevations
Archicad 5
Released: 1996-1997
3D Textures Column Tool Editable Sections
Intelligent Cursor New Software Development Kit New Wall and Roof Construction Methods
QuickTime VR Splines Teamwork
Zone Tool
Archicad 4
Release year: 1991-1995
Platforms: Apple Macintosh, Windows 3.1, Windows 95
Camera Tool Custom Axonometries Extended Arc/Circle
First Windows version First version to appear on both Mac and Window Handling of Alpha Channel
Import Pictures Label Tool Lamp Tool
Line Merge Projects Mesh
PlotMaker improvements Rendering Sections/Elevations generated from Floor Plan
Smarter Text Editing Window/Door
Archicad 3
Release year: 1987-1990
Colors
Archicad 2
Release year: 1986
Integrated 2D and 3D module
Radar CH
Release year: 1984
Platforms: Apple Lisa
Separate 2D and 3D module
Comments
This is a very important and useful article. We refer to it a lot.
Unfortunately, many of the links are no longer alive. Please update them!
Best regards, Robert
Marco Vitruvio Bacus
Dear Robert,
I had Archicad 16-for Windows 32 installer in a USB memory unit that unfortunately I lost. I'm a student and It was provided to me by Graphisoft a while ago. It was the student version though.  I use Archicad 16 because that's what my limited equipment can handle. Had to replace my Hard Drive which after 14 years of service, died. When I got a new Hard Drive and it was time to bring programs and information back to the computer, I realized didn't have the USB which was gone for good. I asked the fellows at Graphisoft for the installer and they told me they don't carry that old version no more and couldn't help me. Could you help me? Do you know of anyone who has the installer? It'd be wonderful if you can. Let me know please. Thanks.
