Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 7522 Views
  • 126 replies
  • 16 likes
Profile Manager V25 Possible Bug
When you try to change the type of the component of a material in the profile editor the option reverts to the initial type when the material was created. You cannot change it. I do not remember this behaviour before......Any idea on this?
Botonis by Advocate
  • 163 Views
  • 2 replies
  • 0 likes
Zoom not working
I have a been working on a project for quite a while and suddenly, I cannot zoom on my plan. It seems the zoom level is stuck on 0.000000% and even if I change this to 100% it will not zoom on my drawing. It looks like an origin problem but I have no...
Resolved! Spiral stair tread depth at walking line?
Hi, I want a specific walking line length of the tread measuer at the outer diameter of the tread. I have moved the walking line but still the length (300mm in my case) is measured at center (where the walking line from the beginning). How do I do th...
Resolved! Curtain wall panel reference line
I am drawing a suspended ceiling using the curtain wall tool. How can I change the reference line from the middle of the panel to the blue line as shown below? In the settings I can only change the blue line which still gives me wrong height of the c...
SarahA by Participant
  • 338 Views
  • 8 replies
  • 0 likes
Resolved! Walls won't change color fill
Hi!We just created a new floor plan and starting to clean everything... I wanted to fill all walls with dark gray or whatever color but it does not react to anything and won't change the color... I think I tried all variants including changing type o...
Resolved! changing fonts and lines based on layer
Hello!'Is there a way to change all text same based by Layer? yes I know how to change text, all text, ... but I need to change text size/font based on layer, the same with lines..... turning off and on layers is lame option, anything else please? af...
‘Master_GDL’ and Attribute Infection
Hello- We are experiencing a persistent ‘Master_GDL’ pollution problem in an embedded library on 2 Teamwork projects. Somehow, a bunch of unwanted master_GDL objects appear in our embedded library.These master_GDL object create a ton of unwanted attr...
RileyDA by Participant
  • 250 Views
  • 5 replies
  • 1 likes
