Views, layouts, publishing: seamless Archicad documentation
Articles
In multi-story interior design workflows, elevation dimensions are typically referenced to the Project Zero by default. This can make it difficult to read room-specific heights, especially when each space has a different finished floor level. Issue description When placing e...
  • 1248 Views
  • 0 likes
  • 0 comments
In Archicad, Schedules typically read door opening orientation directly from element parameters, which limits the level of control over how this information is displayed. For double‑leaf doors, the default “R” or “L” orientation label can be misleading or simply not applicab...
  • 1520 Views
  • 0 likes
  • 0 comments
When working with multiple design schemes in Archicad, it can be difficult to find clear, step‑by‑step guidance on setting up and managing Design Options. This article collects a structured series of Design Options video tutorials by longtime Archicad user @JaredBanks, showi...
  • 2736 Views
  • 4 likes
  • 0 comments
Schedules in Archicad can be configured to display various element types and their properties. However, when working with complex elements like Curtain Walls, Railings, or Stairs, sub-components may appear alongside primary elements, creating cluttered documentation. This ar...
  • 880 Views
  • 0 likes
  • 0 comments
This article describes two ways to manage the Section tool so that the section marker on the floor plan can be positioned independently from the section drawing width on layouts. The methods use a custom GDL Section Marker object and Archicad’s native linked section markers....
  • 1393 Views
  • 0 likes
  • 0 comments
Automating ID assignment for multiple model elements can significantly reduce manual work and errors, especially when a clear spatial sequence is required (for example, rooms along a corridor, parking spaces along a lane, or furniture along a path). This article describes ho...
  • 1448 Views
  • 0 likes
  • 0 comments
Managing many PDF exports in Archicad can become time‑consuming and error‑prone when each file must be renamed manually to reflect project stage, revision, or content. By combining Publisher shortcuts with Autotext, multi‑page PDFs or folder‑based outputs can be named automa...
  • 986 Views
  • 0 likes
  • 0 comments
Efficient documentation relies on clear, well-positioned text annotations. When text boxes do not automatically fit the length of their content, they can appear oversized or awkwardly placed, making layouts less tidy and requiring extra manual adjustments. This article expla...
  • 764 Views
  • 0 likes
  • 0 comments
Organizing sheet indexes efficiently is essential for maintaining clarity and flexibility in project documentation. This article explores a versatile method for grouping layouts in Archicad using custom properties, as well as two alternative approaches for different project ...
  • 1408 Views
  • 2 likes
  • 0 comments
Project documentation often needs to display the clear opening width of doors to satisfy planning and accessibility requirements, but this value is not always available by default in Archicad. This article presents two practical, community‑proven ways to annotate and measure...
  • 1250 Views
  • 1 likes
  • 0 comments
As Archicad projects grow, the Info Box can quickly become crowded with tool options and settings, reducing your available workspace. This article shows a simple way to customize the Info Box so you can work in a cleaner, more focused interface. Issue description When workin...
  • 685 Views
  • 0 likes
  • 0 comments
Custom fills are a simple yet powerful way to give your drawings clarity and add a unique character to your designs. Whether you’re creating repetitive patterns, textures, or importing images, Archicad offers flexible tools to make your elements stand out. This guide highlig...
  • 2722 Views
  • 0 likes
  • 0 comments
Managing PDFs is a key part of any team project, and Archicad offers several tools to keep your documentation up to date, editable, and ready to share. This article walks through how to update PDF drawings, make them fully editable, and publish clean, organized PDF sets from...
  • 2596 Views
  • 0 likes
  • 0 comments
If you’ve ever opened up an Archicad schedule and thought, “How am I supposed to read this?”, you’re definitely not alone. Busy days and complex projects can turn schedules into a mess of numbers and labels pretty quickly. But now, Archicad 29 offers easy fixes that clear th...
  • 3501 Views
  • 1 likes
  • 0 comments
Composing clear, professional layouts is key to quality architectural documentation in Archicad. By combining master layouts, AutoText, lines, fills, and images, you can build drawing sheets that are both attractive and consistent. Below is a complete guide for creating effe...
  • 7718 Views
  • 1 likes
  • 0 comments
Explore how to publish (save) your layouts and documentation from Archicad using Publisher sets, including recommended formats and common options for PDFs, DWG/DXF, and more. Publisher automates consistent output of Views and Layouts into repeatable “sets,” so you can republ...
  • 4542 Views
  • 0 likes
  • 0 comments
3D views are often placed on layouts instead of rendered images. You can now adjust the resolution of these 3D views, allowing you to control image quality or the displayed edge sharpness of the 3D model. NOTE: This feature is available starting with Archicad 29. Here is how...
  • 25081 Views
  • 2 likes
  • 0 comments
Through Project Indexes, you can now find unused views and select them directly from a list of your project views. (Roadmap). This simplifies project organization, as you can quickly clean up your projects from unneeded views and rediscover hard-to-find views in the project ...
  • 24376 Views
  • 1 likes
  • 0 comments
Starting with Archicad 29 Section, Elevation, Interior Elevation, Detail, and Worksheet markers can now receive their own Renovation Status, just like all other documentation and construction elements. This makes it possible to control the visibility of markers directly via ...
  • 24352 Views
  • 2 likes
  • 0 comments
Tired of spending hours manually dimensioning and labeling your drawings? Archicad’s smart automation tools let you create consistent, accurate, and up-to-date documentation with just a few clicks. Here’s how you can boost your productivity and keep errors to a minimum: Auto...
  • 7503 Views
  • 1 likes
  • 0 comments
Lost in a sea of information? Archicad's Keynotes feature is here to help you organize and centralize your annotations, ensuring clarity and consistency across your project documentation. Here’s how you can use Keynotes to simplify your workflow and create professional-grade...
  • 4867 Views
  • 1 likes
  • 0 comments
Maintaining consistency across multiple views in Archicad doesn't have to be time-consuming. Instead of setting each view individually, you can use the Pickup Parameters tool to effortlessly copy and replicate view settings. Follow this guide to streamline your workflow! How...
  • 2925 Views
  • 3 likes
  • 0 comments
What is Keynote in a construction drawing? In a construction drawing, the term "Keynote" refers to a notation system used to identify and describe specific project details. It is an efficient way to provide additional information about architectural elements, finishes, mater...
  • 20620 Views
  • 5 likes
  • 0 comments
Welcome to our series of articles from the One Override To Rule Them All challenge! We invited some of the participants of the challenge to elaborate on their entries, share their workflows and tips & tricks. Enjoy and feel free to start a thread in the Documentation forum i...
  • 6915 Views
  • 8 likes
  • 0 comments
This article aims to provide some insight into our 2D modernization project spanning across multiple Archicad versions. The focus will be on the changes in line rendering and its benefits. As the title implies, the material is recommended for readers interested in the inner ...
  • 11455 Views
  • 6 likes
  • 0 comments
Autotext on Master Layouts is an intelligent Archicad tool that automatically updates documentation-related information in title blocks. However, users needed to add manual text, place specific autotexts for each subset in the Layout Book, or create additional Master Layouts...
  • 18964 Views
  • 6 likes
  • 0 comments
Find and add a rule to a combination When creating Graphic Override Combinations, it can be time-consuming to find and add only one rule at a time to a combination. Now you can perform tasks faster — Graphic Override Combinations let you add multiple rules at a time. Enhance...
  • 12429 Views
  • 5 likes
  • 0 comments
Level Dimension text content was hard to customize The Level Dimensions update in Archicad 26 focuses on avoiding repetitive tasks to save time on creating documentation. These new functions requested by our users make using this tool faster and more efficient. Before Archic...
  • 12259 Views
  • 11 likes
  • 0 comments
Import multiple PDF pages at once Importing external content in Archicad is handy for placing external information such as PDF documents in Viewpoints or on Layouts. Until Archicad 26, it was only possible to import one PDF page from the same selected PDF document at a time,...
  • 20061 Views
  • 3 likes
  • 0 comments
A quick way of keeping your rendered images up-to-date without re-rendering them manually after changing the model is to use the 3D Only panel of the View Settings. Instead of rendering the specific camera views, then saving and placing the final .jpg/.png/etc. files onto th...
  • 5841 Views
  • 2 likes
  • 0 comments
Ever wanted to change how the numbers appear in Archicad, but could not find the settings in the Dimension Preferences? By default all numbers are showing commas for digit grouping and full stops for decimals. This can be very easily changed in the system settings of your OS...
  • 10800 Views
  • 2 likes
  • 0 comments
Since there is no perfect solution for labeling an abbreviation (ID or code) of elements, mainly the Surfaces, two main ideas emerged other than using external label objects: use Labels along with Properties or IFC mapping. Though the first may seem to be easy to set up with...
  • 11082 Views
  • 2 likes
  • 0 comments
Transparency and Vectorial Hatches ( renamed as Surface - Cover Fill Foreground in AC 25) are some nice features of the 3D Documents, so the wish of combining these two for a single surface at some point (for example displaying mesh-like surfaces) is quite reasonable. Let’s ...
  • 8604 Views
  • 5 likes
  • 0 comments
Note: The steps described in this article are still applicable for the latest version. The expected outcome of site plan as per the Singapore standards are achievable only by the workaround given in the article. Site plan shows Plan of the buildings from top view (elements c...
  • 22523 Views
  • 3 likes
  • 0 comments
Archicad now allows the user to hotlink multiple blocks with different story settings. Only item that need to be taken care is Level Markings as it do not come from the hotlink file and users have to mark the level with lines and text. The object SectionLevel_GSSG was create...
  • 10394 Views
  • 3 likes
  • 0 comments
Got a huge amount of folders in your View Map and/or in the Layout Book and want to see all their content expanded? Select the folder and use: ALT+right arrow (MAC) and * (Windows) to expand all within the selected folder ALT+left arrow (MAC) and – (Windows) to collapse all ...
  • 17335 Views
  • 5 likes
  • 0 comments
There are times when you need a Drone view of the building to show in Master Plan. All you need is the outline of the building, but it takes a lot of time to get a clean and crisp overall boundary of the entire project. And, in case there are updates and re-submissions, the ...
  • 7690 Views
  • 1 likes
  • 0 comments
Open & Repair is one of the most useful commands in Archicad, it is the solution to many common issues. The purpose of the repair process is to physically fix damaged files. When the damage occurs, one or more parts of the file become corrupted or lost. The Archicad Plan Fil...
  • 9866 Views
  • 5 likes
  • 0 comments
In this article you can find out how to create a simple custom Drawing Title without GDL coding. 1. Draw your custom Drawing Title Navigate to a Floor Plan View Set the scale to 1:1 to get the paper-size portions (because that is how it will be represented on layouts). Use t...
  • 14376 Views
  • 8 likes
  • 0 comments
This is one of those handy tips can save a lot of time to newcomers. Instead of the tedious job of exploding your polyline to fillet with arcs, follow the below steps: select the polyline pick a corner node (not along a section of line) left-click on one of the corner nodes ...
  • 7676 Views
  • 1 likes
  • 0 comments
With the improved Graphic Overrides now RGB colors can be selected for Background Fill Pens and 3D surfaces in Graphic Override rules. This way, you do not have to create separate pens and surfaces with a specific color to highlight elements if you would like to synchronize ...
  • 8367 Views
  • 4 likes
  • 0 comments
In this article we want to provide some tips and tricks to supplement or enhance architectural drawings. Architects need enhanced architectural drawings to be able to represent their design concept efficiently. Of course, you have to start with a proper model in Archicad. St...
  • 12920 Views
  • 5 likes
  • 0 comments
Occasionally you may want to generate a contour map of the terrain of your project. The 3D terrain can be imported from an external source, thus can be an object or a morph in ARCHICAD or can be a mesh created in ARCHICAD. The default Floor Plan representation of these eleme...
  • 18883 Views
  • 4 likes
  • 0 comments
In order to set up the path for only one layout, you have to set the path for the whole set, because the publishing path can be defined only on the level of the sets. To accomplish this there are two ways: The first way: Go to the Publisher Sets in the Navigator.Select the l...
  • 12704 Views
  • 2 likes
  • 0 comments
To create a New Fill, you need to open Options/Elements Attributes/Fills panel. There you can edit all the existing Fills and add new ones. By clicking on the New... button you get the choice to create a new Solid fill, a new Symbol, a new Image Fill, or Duplicate an existin...
  • 38691 Views
  • 3 likes
  • 0 comments
With the introduction of expressions in ARCHICAD 22 users can extract and manipulate information from the model. Follow the steps below to learn how to take the name of a composite and abbreviate it for use in a partition tag. 1. Go to Options > Composites to open the compos...
  • 9974 Views
  • 4 likes
  • 0 comments
A manually created Custom Drawing Title has its limitations. The best way to create a Drawing Title that is highly customizable is by creating it through GDL coding, but with the instructions in this article you can turn your manual Custom Drawing Title into an enhanced vers...
  • 9795 Views
  • 6 likes
  • 0 comments
Similar to how font and paragraph styles work we can create and store favorites for Text Styles in ARCHICAD. What are Text Style favorites? First of all, what settings do Text Styles contain? We can customise the following settings: Using these settings we can define the sty...
  • 5865 Views
  • 0 likes
  • 0 comments
Often times a PDF is the only file type available for certain content. Fortunately ArchiCAD allows you to import and convert the vector information into usable elements. Please follow the steps below to import and explode PDFs in ArchiCAD. Importing PDFs 1. Create a new work...
  • 14508 Views
  • 0 likes
  • 0 comments
How do we make a mesh cut line in section dashed? - asked by nickATA on ARCHICAD-TALKOne of our users posted this question on ARCHICAD-TALK about how to make an uncut line of a Mesh dashed on a section. The situation described was with two meshes (one existing and one propos...
  • 6296 Views
  • 3 likes
  • 0 comments
ARCHICAD allows users to quickly apply hatches and shadows to elevations and sections. To enable shadows and 3D vectorial hatching, please follow the steps below. Navigate to Elevation or Section. Open the Elevation (or Section) Settings dialogue box of the current viewpoint...
  • 23894 Views
  • 1 likes
  • 0 comments
Fills are geometric 2D hatching patterns that help you distinguish and decorate the elements of your project. They can also be used to decorate surfaces in the 3D window and the 3D Documents. ARCHICAD comes with a full set of Fills that are available in the Fill Types Dialog...
  • 8042 Views
  • 0 likes
  • 0 comments
One of the advantages to modeling in 3D is that the project file can be easily exported to a 3D printer using the STL (StereoLithography) file format. Follow the steps below to export the model as an STL. Readying the Model for Export 1. Open the model in 3D. 2. Hide the lay...
  • 12214 Views
  • 0 likes
  • 0 comments
There are two ways to label stairs in a section: manually (one by one) or automatically. The manual way is to use the Label Tool, find the Stair Riser Step Index and Stair Tread Step Index from the favorites, which are included in the default Archicad template. To create thi...
  • 12378 Views
  • 4 likes
  • 0 comments
Is it possible to set two dimensioning methods in ARCHICAD in one project? - asked on FacebookThis question can be interpreted many ways, let's summarise what we know about dimensioning, what we can and can't do. Setting up the units in the project First of all, it is import...
  • 17894 Views
  • 1 likes
  • 0 comments
What is an expression? An expression is a mathematical phrase which combines numbers, variables and operators to show the value of something. Being introduced in Archicad 22, expression-based element properties can come in hand when we want to create custom property values, ...
  • 8427 Views
  • 5 likes
  • 0 comments
The Angle Dimension tool can be found in the toolbox palette, under the “More” group of tools: Angle Dimensions display angle values: between a pair of lines or linear edges or the angle of a curved element NOTE: Angle dimensions are not available in the 3D Document Window. ...
  • 25629 Views
  • 0 likes
  • 0 comments
ARCHICAD construction elements on a floor plan usually can have 3 different displays. projection projection with overhead cut only Using Projection with overhead is a similar look for different element types: There are a few exceptions though, having additional floor plan di...
  • 5768 Views
  • 0 likes
  • 0 comments
In case we would like to show our elements on other stories as well, one might wonder where to set the line type for the display one story above or below? In case of three basic elements, slabs, objects and meshes, we can set this under Project Preferences/Legacy. As the not...
  • 6176 Views
  • 3 likes
  • 0 comments
The Grid Tool in ARCHICAD allows elements placed in plan view to show in Elevation and Section. Enabling Grid Elements in Elevation or Section Select the elevation or section in the project map and click the settings button. In the Elevation/Section Selection Settings dialog...
  • 16442 Views
  • 0 likes
  • 0 comments
NOTE: the available Pen Sets and their parameters can be different in every language version. In this case, this PEN SET theory doesn't apply to the U.S. version The Pens and Colors Settings Dialog is available in Options > Element Attributes > Pens & Colors. The Pen Table i...
  • 19415 Views
  • 4 likes
  • 0 comments
This article outlines the floor plan representation of staircases using the new Stair Tool. We took a U-Shape stair as an example and followed it through 3 stories. The example in this description is a staircase with a story setting of First Floor 3000 Ground floor 4000 Base...
  • 14737 Views
  • 1 likes
  • 0 comments
There are many ways to make use of vectorial PDFs in ARCHICAD. Below You can read about are the most commonly used features and tricks. Saving PDFs from ARCHICAD You have two options to save PDF from ARCHICAD: Publish You can also publish PDF documents by setting up Publishe...
  • 11178 Views
  • 1 likes
  • 0 comments
Introduction As of version 17 Archicad can directly save and open Stereolitography (.stl) files using the built-in STL In-Out Add-On. STL File Format STL files only carry the surface geometry of a 3D model without any additional information such as color, material etc. It co...
  • 20695 Views
  • 2 likes
  • 0 comments
PlotMaker was a layouting program that was part of the ARCHICAD package. This standalone application was optimized to prepare an architectural documentation set based on the views, drawings and images created in ARCHICAD. PlotMaker could also accommodate data from external s...
  • 10713 Views
  • 0 likes
  • 0 comments
Missing Elements in 3D (and 2D) Views If you notice missing elements or a blank window, the following possibilities are worth to check: 3D There is no missing macro in libraries (this sometimes aborts model creation) No 3D cut plane is turned on (View/ Elements in 3D View/ 3...
  • 22636 Views
  • 0 likes
  • 0 comments
Create Symbol Line Type In our special example we are demonstrating how to create line types with letters in it, but the described steps can be applied to any custom line type. When creating custom line types, the stencil of the symbol may be drawn on your Floor Plan using t...
  • 28223 Views
  • 2 likes
  • 0 comments
Both printing and plotting are available in Archicad. However, there are differences between them. This document outlines which method you should use, depending on your task. For more information, see Print and Plot in Archicad Help. Features available with both printing and...
  • 7539 Views
  • 0 likes
  • 0 comments
U3D (“Universal 3D”) is a file format for 3D data. It is a standardized three-dimensional data format with the purpose of facilitating 3D data exchange among programs of various kinds. Adobe Acrobat supports this format from version 7.0, so within a PDF documents 3D models c...
  • 14033 Views
  • 2 likes
  • 0 comments
The article is based on Dan Kunschik’s original post on ARCHICAD-Talk and has been updated for ARCHICAD 15. Summary of steps To create a curved text in ARCHICAD, a few tricks need to be employed. Text (created with the TextTool) can not be curved, so a symbol linetype has to...
  • 15363 Views
  • 2 likes
  • 0 comments
The Drawing and Figure tools are Archicad features that allow the user to deal with drawings and images. Even though those tools might sound similar, they can be used for different purposes. The following chart shows their usage differences. Drawing Tool Figure Tool What it ...
  • 7312 Views
  • 1 likes
  • 0 comments
Files saved from ARCHICAD in 2D formats (PDF, DWG, DWF...) can be unusually large because of fill and line types used in the drawing. "symbol" type fills and "symbol" type lines explode in DWG and PDF - one line in archicad can break up to thousands or millions of small line...
  • 11395 Views
  • 4 likes
  • 0 comments
About the Renovation Feature Element-level Definition of Renovation Status No need to create extra layers: just set a default Renovation Status (Existing, New, To Be Demolished) for all element types. Switch Renovation Status of any/all selected elements with a single click....
  • 11058 Views
  • 1 likes
  • 0 comments
See also: http://www.cadalyst.com/aec/how-display-elevation-values-relative-sea-level-archicad-insights-tutorial-3714 Level Dimensions Level Dimensions are point-level elevation markers common to architecture and site planning. They measure the element’s vertical height alon...
  • 9856 Views
  • 0 likes
  • 0 comments
This article explains how to create details in Archicad and choose the right workflow: using the Detail tool for project‑specific, model‑based details, or using an Independent Worksheet for reusable standard details. Worksheet vs Detail Use the Detail tool for project‑specif...
  • 6105 Views
  • 0 likes
  • 0 comments
There are several ways you can split a Line in ARCHICAD. The following describes some of the basic methods. (There are probably other methods you could come up with). Splitting a Line with Another Element In this example, we wish to cut the near-horizontal Line with the othe...
  • 18021 Views
  • 0 likes
  • 0 comments
Originally published at AECBytes: http://aecbytes.com/tipsandtricks/2008/issue35-archicad.html. Written by Eric Bobrow (Principal, Bobrow Consulting Group) ARCHICAD makes it easy to create a Virtual Building, a 3D Building Information Model (BIM) of an architectural design w...
  • 27806 Views
  • 0 likes
  • 0 comments
