Document articles
Articles
ARCHICAD 18 Revision Tool troubleshooting guide
Revision History library object, line spacing issue Affected version: 18 | Severity: no workaround applicable | ID: 172837 Note: This issue was fixed in ARCHICAD 19 release version. Issue The line spacing of the Revision History object is lofty if on...
wp-content_uploads_images_Screen-Shot-2014-06-20-at-15.49.03-e1403272231414.png wp-content_uploads_images_Screen-Shot-2014-06-20-at-15.55.03-e1403272528966.png
Dimensions/Labels - Troubleshooting Guide
Known Issues Labels may be dislocated when opening an ARCHICAD 19 project in ARCHICAD 20 Affected version: 20 | Severity: workaround applicable | ID: 201188 Due to a fix in ARCHICAD 20 which corrects the position of mirrored and associated Labels cou...
wp-content_uploads_2016_06_mirrored-labels-1024x665.png wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_archicadwiki_troubleshooting-cutplanedimensionloss--dim222.png wp-content_uploads_archicadwiki_troubleshooting-cutplanedimensionloss--dim111.png
How to Create Custom Line Types
Create Symbol Line Type In our special example we are demonstrating how to create line types with letters in it, but the described steps can be applied to any custom line type. When creating custom line types, the stencil of the symbol may be drawn o...
wp-content_uploads_archicadwiki_customlinetypes--1.jpg wp-content_uploads_archicadwiki_customlinetypes--3.jpg wp-content_uploads_archicadwiki_customlinetypes--5.jpg wp-content_uploads_archicadwiki_customlinetypes--open.png
automata by Graphisoft
  • 7052 Views
  • 0 comments
  • 2 likes
Editing Grids
Best Practice Grids are best set before sharing the project. If it is necessary to edit a grid element, it is best to have all other users release their reserved elements and you reserve all of the elements in the project. If your organization is lar...
wp-content_uploads_archicadwiki_teamwork-editinggrids--gridoffinwe.jpg wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_archicadwiki_teamwork-editinggrids--gridinfotag.png wp-content_uploads_archicadwiki_teamwork-editinggrids--gridinfotag2.png
  • 811 Views
  • 0 comments
  • 0 likes
Display Order
When drawing a Project with ARCHICAD, overlapping elements will be drawn according to a specified stacking order. About Drawing Index When using the Bring Forward/ Bring to Front/ Send Backward/ Send to Back commands, ARCHICAD uses an internal index ...
wp-content_uploads_archicadwiki_displayorder--bring.png wp-content_uploads_archicadwiki_displayorder--tablazat.png wp-content_uploads_archicadwiki_displayorder--display_order.jpg
  • 1637 Views
  • 3 comments
  • 0 likes
Print Versus Plot
Both Printing and Plotting are available in ARCHICAD. In ARCHICAD 10, Printing and Plotting have been brought onto a “common platform” which resulted in the Print and Plot dialog boxes becoming similar to each other. However, there are still differen...
wp-content_uploads_archicadwiki_printingplotting--printplot-01.png wp-content_uploads_archicadwiki_printingplotting--printplot-03.png wp-content_uploads_archicadwiki_printingplotting--printplot-02.png wp-content_uploads_archicadwiki_printingplotting--printplot-04.png
Anonymous by Not applicable
  • 768 Views
  • 0 comments
  • 0 likes
Autotext Annotation
See also: How to Insert Autotext in ARCHICAD Help. The ProjectInfo database can be used as a location for stored annotations. These annotations can be then inserted into the project with AutoText. If you work on a plan where the annotations belongs t...
wp-content_uploads_archicadwiki_autotextannotation--01.jpg wp-content_uploads_archicadwiki_autotextannotation--2.jpg wp-content_uploads_archicadwiki_autotextannotation--3.jpg wp-content_uploads_archicadwiki_autotextannotation--4.jpg
How to make Curved Text in Archicad
The article is based on Dan Kunschik’s original post on ARCHICAD-Talk and has been updated for ARCHICAD 15. Summary of steps To create a curved text in ARCHICAD, a few tricks need to be employed. Text (created with the TextTool) can not be curved, so...
wp-content_uploads_archicadwiki_curvedtext--textarea.png wp-content_uploads_archicadwiki_curvedtext--alignment.png wp-content_uploads_archicadwiki_curvedtext--linesegment.png wp-content_uploads_archicadwiki_curvedtext--naming.png
  • 2551 Views
  • 0 comments
  • 1 likes
