Project data & BIM
Read articles about BIM-based management of attributes, schedules, templates, favorites, hotlinks, projects in general, quality assurance, etc.
Articles
Why is an office template strategy important?
An office template is a predefined, “empty” file that contains all the necessary information for starting a new project, based on the applicable national and company CAD/BIM standards. An office template will dictate that all new projects work to an ...
What is data, and why is it important?
Data strategy in Archicad is the structured planning and management of model information to ensure consistent, accurate, and standards-compliant data for design, documentation, and collaboration. We know that a BIM project cannot rely solely on a gre...
What is the role of a BIM Coordinator?
A BIM Coordinator is a professional who ensures that all project models are accurate, consistent, and well-coordinated across disciplines to support smooth collaboration and compliance with BIM standards. With the penetration of BIM in the constructi...
Archicad Template Types
Starting with Archicad 28, the Built-in Generic Template is a direct copy of the International (INT) Template, available in all regions. This means that unless you use a localized Online Template, your new projects will use the global INT version, wh...
Improved Project Management
Continuing our focus on enhancing project manageability, Archicad 27 includes highly requested additions to the attribute management workflow. This update helps increase the efficiency of design teams, by letting more attributes be organized using a ...
EmokeCsikos_0-1695401499841.png EmokeCsikos_1-1695401499844.png EmokeCsikos_2-1695401499848.png EmokeCsikos_3-1695401499852.png
Occupancy Design Validation with Expressions
A new feature of ARCHICAD 22 helps to turn the raw data into meaningful and valuable information. The expression-based properties process model data with functions and operators to produce new information which was not available directly in ARCHICAD....
wp-content_uploads_2018_06_Occupancy_expressiosn.png wp-content_uploads_2018_06_occupancy_expressions_2.png wp-content_uploads_2018_06_occupany_expression_3.png wp-content_uploads_2018_06_occupancy_expression_4.png
Scheduling Formwork Quantities
Archicad has two great features which can greatly help contractors with listing formwork quantities more precisely than ever – and faster too First we will dedicate a Surface to represent formwork materials, then list the surface areas. This has been...
screen-shot-2016-03-21-at-15-58-56.png screen-shot-2016-03-21-at-16-14-06.png screen-shot-2016-03-21-at-16-16-19.png screen-shot-2016-03-21-at-16-18-07.png
Element Previews in Schedules
From ARCHICAD 20 on the Interactive Schedule includes fields for graphic previews (2D and/or 3D) of any construction element ‐ not just Library Parts. The preview, a simplified thumbnail, is helpful in describing construction typologies within the pr...
wp-content_uploads_ac20_help_NewFeatures.03.13.1.png wp-content_uploads_ac20_help_03_2_Views_Virtual_Building.08.124.3.png
mtron Graphisoft | Graphisoft
  • 5619 Views
  • 1 comments
  • 1 likes
Expression-based properties FAQ
Expression-based properties have been introduced as one of the main new features in ARCHICAD 22 to help designers in creating data-rich building models. Expressions process existing model data with functions and operators to create new information. F...
Zone Areas and Volumes
Zone area and volume calculations may seem to be tricky sometimes when you can’t track which areas are calculated exactly and how. In the following I will try to clarify the differences between the area types and why they may or may not show up when ...
EcoDesigner STAR
Table of Content AvailabilityFrom BIM (Building Information Model) to BEM (Building Energy Model) directlyEcoDesigner STAR workflowEvaluation for any climate or locationEcoDesigner STAR feature highlightsMultiple Thermal BlocksThermal Bridge simulati...
wp-content_uploads_2020_05_EDSTAR_LOGO_final.png wp-content_uploads_2020_05_Wildbanners_pr1.jpg wp-content_uploads_2020_05_climates01-100x100.png wp-content_uploads_2020_05_climates02-100x100.png
Replacing missing fonts between Macintosh and Windows
Architects who cooperate with colleagues working on a different platform than they work on can sometimes experince the problem of missing fonts. Let's see what you need to do to overcome this issue. The file named XreadCfg.txt that is located in the ...
wp-content_uploads_2016_05_01.png wp-content_uploads_2016_05_02.png wp-content_uploads_2016_05_03.png Screenshot 2023-02-09 102257.png
Converting old Archicad Files
You can choose from the below listed Archicad File converters to convert your Archicad files to a format which is supported by current Archicad versions. The latest Archicad File converters can be find on Graphisoft.com. You can also find the FAQ on ...
  • 25450 Views
  • 3 comments
  • 0 likes
Accurate Schedules and Quantity Takeoffs with Archicad
Archicad 25 introduces new properties for more accurate component Lists. You could schedule only the net value of component areas and component volumes in earlier versions: the holes were always subtracted. As of AC25, new "gross" and "conditional" a...
wp-content_uploads_2021_05_Untitled-480p-210531.gif wp-content_uploads_2021_05_image-5.png wp-content_uploads_2021_05_image-6.png
Hotlinked Modules
Archicad provides two basic methods for sharing/dividing BIM project data among a team of architects: Teamwork method for sharing projects, Hotlink method for dividing complex projects into smaller parts. These two methods are most effectively used i...
wp-content_uploads_2018_07_HLM-explanation1.png wp-content_uploads_2018_07_HLMs-selection-1024x663.png wp-content_uploads_2018_07_HLM-Manager-1006x1024.png wp-content_uploads_2018_07_2-HLM-Explanation-NESTED.png
Search in the Navigator
Scroll to find a specific Navigator item Nowadays, a project can have hundreds of sections, elevations, details, 3D views, and layouts – all listed in the Navigator. With the increasing complexity and size of projects, it is becoming time-consuming t...
OleksandraVakariuk_0-1653305552663.png OleksandraVakariuk_1-1653305552668.png OleksandraVakariuk_2-1653305552671.png
Data Safety, File Recovery and Troubleshooting
Archicad usually got you covered by sophisticated solutions in case of a crash, apparent data loss or file damage, but sometimes manual recovery or troubleshooting might be needed. The following post collects the backup and recovery options and the l...
Quick Tip for Publishing Hotlinks in Large Projects
Just recently came across this issue that unit modules were meant to be linked into a block file, but due to the large amount of small variations within the units, the designers wanted to have a base module to link into the unit file as well, such as...
Archicad as a Coordination Tool
Every now and then the question arises: how to use Archicad as a coordination tool. There are multiple workflows in which you can differentiate and compare the models of different disciplines. Let’s take a look at the following model where architectu...
Migrating Classifications
There are a lot of cases – even if it is not entirely intentional when you migrate projects. This happens when content made in an earlier version of Archicad is opened in a newer version. These scenarios can include: simple copy-paste from your old p...
Multiple Area Units in Zone Stamps
I initially wanted to include three topics in one post, then I realized it would be easier to find them later if they were broken down into shorter parts, though they could be related as well. Let’s start with displaying different area units in Zone ...
Using Geometry Information as Scheduling Criteria
This is to follow up the post earlier on Multiple Area Units in Zone Stamps and take the next step after converting the area units – it is going to be a very short one As you have seen in that post, we converted the area to a different unit than the ...
Schedules with Zero Values
Archicad Schedules can only list existing elements by default, but we can use a bit of a trick to go around this behaviour and list what is not really there as well. This is needed sometimes when the user wants to create a schematic section for examp...
Polygon Reduction in Archicad
If your model is feeling laggy or sluggish, especially in 3D, it may be due to a high number of polygons in the model and on-screen. For example, when navigating in 3D, there is a drop of frames (image stutters).This article can help you to identify,...
How to prepare the BIM model for the Energy Evaluation
Archicad models have to be prepared to be able to run precise energy simulations in Energy Evaluation or in EcoDesigner Star. The more precise the model, the more precise the energy calculation you get. Geometry, Building Materials, and Priority Base...
Energy Evaluation
BIM-integrated Sustainable Design Archicad’s improved Energy Evaluation engine supports multiple thermal blocks. This allows users to evaluate their designs with standard-compliant technology and makes Archicad the “greenest” BIM solution available o...
wp-content_uploads_2020_05_ecodesigner-background2.jpg wp-content_uploads_2020_05_EDSTAR_LOGO_final.png
Scheduling Doors by Zone
ARCHICAD allows users to schedule their doors by zone. Please follow the steps below to learn how to setup a door schedule and how to change the zone a door belongs to. Create a Door Schedule In this example we will only be setting up a schedule that...
wp-content_uploads_2018_11_door_zone_shcedule_in_ARCHICAD1-300x164.png wp-content_uploads_2018_11_Navigator_Schedule_ARCHICAD.png wp-content_uploads_2018_11_new_schedule_ARCHICAD.png wp-content_uploads_2018_11_Door_schedule-1024x710.png
How to transfer Attributes in ARCHICAD
ARCHICAD allows us to transfer attributes between projects. For that you need to use the Attribute Manager’s Import function. You can import the attributes from .pln and .pla files or .tpl and .xml files, and still .aat file format is supported in or...
wp-content_uploads_2018_06_import.jpg wp-content_uploads_2018_06_Temporary.jpg wp-content_uploads_2018_06_transfered.jpg
Archicad 25 sudden file size increase
With Archicad 25 Graphisoft has implemented many exiting new features and improvements. For more information please visit this page . Symptoms At the same time the released Archicad 25 3002 build has raised an issue (DEF-6049), some projects might su...
Far From Origin - Troubleshooting Guide
About origins in Archicad Why can projects be located far from the origin?Potential issuesTypical visible signsHow offsetting worksCheck your projectFix your projectRelocate projects placed far from the Project OriginA worksheet is far from the origi...
wp-content_uploads_archicadwiki_farfromorigin--origin.png wp-content_uploads_archicadwiki_farfromorigin--origin3d.png wp-content_uploads_2018_01_2FL-here-01-300x158.png wp-content_uploads_2018_01_far-from-origin-300x157.png
  • 20633 Views
  • 0 comments
  • 5 likes
How to set a path that works on both Windows and macOS
In a collaboration environment, it is a common issue that in a project, if you set a file path (e.g. for publishing) to a network location on Windows, it may not work when opening the project on macOS or vice versa. You will need to re-enter the path...
wp-content_uploads_2021_08_connect-to-server.png wp-content_uploads_2021_08_login-items.png wp-content_uploads_2021_08_add-network-drive-win10.png wp-content_uploads_2021_08_add-network-drive.png
Freeze - Troubleshooting Guide
A "freeze" or "hang" is the state of the program when it does not respond to the operating system. A situation when Archicad does not respond to user actions (You see the hourglass on PC or the beachball on Mac ) does not necessarily mean it's frozen...
wp-content_uploads_2021_05_minidump.png Info_18x18.png wp-content_uploads_2017_01_Activity-Monitor-1.png wp-content_uploads_2017_01_Save-Sample.png
How to optimize a project's file size
Although a project's performance is the most important, sometimes the large size of a file can be a problem. This article helps you learn what data is stored in a file and how to achieve a balanced BIM project that does not occupy more storage space ...
Python Connection in Archicad
If you've ever spent hours doing repetitive tasks - like assigning numbers to parking spaces one-by-one, finding any unused items in the View Map, or editing each element ID due to multiplying - you know how tedious and error-prone these tasks can be...
wp-content_uploads_2020_10_Python1-Install-now-1.png wp-content_uploads_2020_10_Python2-customize.gif wp-content_uploads_2020_10_macos_Python-install-4.png wp-content_uploads_2020_10_macos_Python-install-5.png
Issue Management and Model Comparison Improvements
Archicad 24 Update 2 brought a few improvements in the area of issue management and handling changes in the project. Read this article to learn the details. Custom Defined Issue Tag: Type Categorize your issues by Type. Applying the Type tag to the i...
wp-content_uploads_2020_11_Type-tag.png wp-content_uploads_2020_11_Issue-deatil.png
How to Optimize Your Project Performance
As projects evolve, they naturally become more and more complex and detailed. Also approaching deadlines might shift the focus from precise modeling to getting the job done. These might result in heavier files than necessary, that can slow down your ...
File Damage or Corruption - Troubleshooting Guide
Possible issues of file corruptions When opening Archicad project files, you might experience that the file is not opened correctly. In some cases the file will not open, in other cases the file opens but some or all of the content is missing. Here a...
Warning.png Repair.png Error.png wp-content_uploads_2017_01_Open-and-repair-1.png
  • 42820 Views
  • 0 comments
  • 5 likes
Issue Management in Archicad and Other Applications
Archicad offers solutions for creating, tracking and handling issues, providing a solid platform for proper issue management during the architectural design process. Archicad's Issue Management functionality supports an extensive collaborative workfl...
One ongoing task of a lead architect or project manager is to ensure that errors, problems, and issues found during the design process are managed and resolved. The number of issues arising during an average project can be large, and resolving and tr...
wp-content_uploads_2020_06_issue-management-in-archicad.png wp-content_uploads_2020_05_add-to-new-issue.png wp-content_uploads_2020_05_new-issue.png wp-content_uploads_2020_05_details-of-issue.png
BIMcloud as a Project Coordination Platform
As the world of AEC has become more deeply interconnected, so have the different disciplines with their myriad of various platforms, software tools and file types. In times of a digital transformation, it’s great to see these all converging into one ...
Model Checking in Archicad
It is essential to find modeling errors in architectural models and correct them before sending them to structural engineers or other stakeholders. The effectivity of the coordination between disciplines largely depends on the quality of the model. A...
wp-content_uploads_2020_05_Physical-Model-Quality.png wp-content_uploads_2020_05_Structural-Analytical-Model-Quality.png wp-content_uploads_2020_05_Collision-Detection.png wp-content_uploads_2016_06_Info_18x18.png
Model Comparison, Visualizing Model Changes
Building Information Models continuously change during the various phases of design and documentation. Keeping track of changes made by all the members of the team is very important and can be challenging. Archicad's Model Compare lets you compare tw...
wp-content_uploads_2020_05_models-to-compare.png Info_18x18.png wp-content_uploads_2020_05_Select-Views-to-compare.png wp-content_uploads_2020_05_Hotlink-Module-Manager-Compare.png
Project and File Management on BIMcloud
BIMcloud (from version 2020.2) is a multi-disciplinary model hub, able to host all file formats* coming from various collaboration tools and accessible by all project stakeholders. All files are managed with the help of the BIMcloud Project and Teams...
wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_2020_05_BIMcloud-project.jpg wp-content_uploads_2020_05_image-2.png wp-content_uploads_2020_05_image-6.png
How to Transfer External Links with Your Project
If you are planning to work on your project from home or a different office, or you need to move it to a different server or BIMcloud, you will also need to consider all the external files you have been using with your project that are not included i...
Archicad FastLogger Files
What is the FastLogger folder? FastLogger is a folder created by Archicad and related tools, in which binary log files are written while the program is running, in order to help with troubleshooting. The size of the folder will be a maximum of 100 MB...
  • 15321 Views
  • 0 comments
  • 4 likes
Migrating a Project Using the Archicad 10 File Converter
The ArchiCAD 10 file converter allows users to migrate their files versions 6.5, 7 and 8 to ARCHICAD 10. This file can then be opened in the current version of the software. If you have already installed the ARCHICAD 10 file converter please navigate...
wp-content_uploads_2018_12_Screen-Shot-2018-12-04-at-11.00.07-AM.png wp-content_uploads_2018_12_Screen-Shot-2018-12-04-at-11.00.22-AM.png wp-content_uploads_2018_12_Screen-Shot-2018-12-04-at-11.00.31-AM.png wp-content_uploads_2018_12_Screen-Shot-2018-12-04-at-11.00.51-AM.png
Project Migration Overview
File Compatibility • ARCHICAD 27 and newer versions can open PLN files back to version 17. • ARCHICAD 26 and earlier versions can open PLN files back to version 8.1. • ARCHICAD 6.5, 7.0 and 8.0 files may be opened in the ARCHICAD 10 file converter. O...
Adding Zones to a Thermal Block
Things to Remember Before Starting Zones are only visible in 3D if they are enabled in the Filter and Cut Elements in 3D dialogue box. It's a good idea to save a 3D view specifically for use with energy evaluation. This view should show all parts of ...
wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_2019_01_Screen-Shot-2019-01-07-at-10.49.20-AM-copy-2-1.png wp-content_uploads_2019_01_Screen-Shot-2019-01-07-at-10.53.18-AM.png wp-content_uploads_2019_01_Screen-Shot-2019-01-09-at-11.02.26-AM.png
Creating Thermal Blocks for Energy Evaluation
If you don't know yet how to prepare the BIM model for the Energy Evaluation, take a look at the checklist here. Before running an energy evaluation of your project file, Thermal Blocks must be created. All Thermal Blocks have an assigned Operation P...
wp-content_uploads_2019_01_Screen-Shot-2019-01-07-at-10.49.20-AM-copy.png wp-content_uploads_2019_01_Screen-Shot-2019-01-07-at-10.49.20-AM-1.png wp-content_uploads_2019_11_Add-Zone-to-selected-Thermal-Block.png wp-content_uploads_2019_01_Screen-Shot-2019-01-07-at-10.49.20-AM-copy-3.png
Creating an Operation Profile
Operation Profiles is an ArchiCAD attribute that can be assigned to a Thermal Block. Each profile is associated with a daily schedule that includes required internal temperature range, human heat gain, hot water needs and humidity loads. Follow the s...
wp-content_uploads_2019_01_Screen-Shot-2019-01-10-at-9.06.09-AM.png wp-content_uploads_2019_01_Screen-Shot-2019-01-10-at-9.06.16-AM-1-300x202.png wp-content_uploads_2019_01_Screen-Shot-2019-01-10-at-9.06.30-AM.png wp-content_uploads_2019_01_Screen-Shot-2019-01-10-at-9.07.51-AM.png
New and Reset All
The New and Reset all command is a useful way to troubleshoot minor issues you may be experiencing in ArchiCAD. Important! - Preparation 1. Save your open project(s). 2. Store and export your current Work Environment. Steps 1. In ArchiCAD, hold down ...
Info_18x18.png wp-content_uploads_2018_10_Screen-Shot-2018-10-02-at-10.00.21-AM.png
Preferences Cleaning with Preparatory Steps
Archicad saves ‘Preferences’ and ‘Work Environment’ files on your computer to ensure you find your own customized environment next time you start Archicad. In rare cases these files can become corrupt, leading to issues within the program. In such ca...
Using Graphic Overrides for Project Auditing
Graphic Overrides provide users with a tool to highlight and visualize a project and they are also a fantastic way to audit a file. They can be used to identify code issues, elements placed incorrectly, static dimensions and many other issues. Below ...
Using Graphic Overrides to Check Element Layer
During the the course of a project elements can be placed on the wrong layer. When this happens, drawings, schedules and other areas of the project can be affected. Follow the steps below to use Graphic Overrides to locate elements on the wrong layer...
wp-content_uploads_2018_09_Screen-Shot-2018-09-25-at-10.09.57-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-26-at-11.13.03-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-26-at-11.13.12-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-25-at-10.24.26-AM.png
Using Graphic Overrides to Check Element Position
During the IFC collaboration it is important to set element position to either Exterior or Interior. Follow the steps below to use Graphic Overrides to see how elements are assigned. 1. Go to Document > Graphic Overrides > Graphic Override Combinatio...
wp-content_uploads_2018_09_Screen-Shot-2018-09-25-at-10.09.57-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-25-at-10.10.37-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-25-at-10.10.43-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-25-at-10.24.26-AM.png
Using Graphic Overrides to Locate Static Dimensions
During the course of a project dimensions that were once associative can be turned static. Whether this is intentional or accidental, it is important to keep track of values that no longer reflect changes in the model. Follow the steps below to use G...
wp-content_uploads_2018_09_Screen-Shot-2018-09-19-at-12.30.42-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-19-at-12.30.57-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-19-at-12.31.21-PM-1.png wp-content_uploads_2018_09_Screen-Shot-2018-09-19-at-12.37.41-PM.png
Optimizing Mesh Performance
Factors that Affect Performance The mesh tool is great way to create topographic volumes within a project. It can also hinder performance if used incorrectly. Meshes that are overly complex take much longer to regenerate due to the number of polygons...
wp-content_uploads_2018_09_Screen-Shot-2018-09-14-at-10.59.01-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-14-at-11.00.55-AM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-14-at-1.42.51-PM.png wp-content_uploads_2018_09_Screen-Shot-2018-09-17-at-2.20.32-PM.png
Exporting, Storing & Restoring Your Work Environment
Store & Export Your Work Environment If you ever uninstall ARCHICAD or apply another Work Environment Profile there is a chance you could lose your custom settings unless you have stored and exported them. Follow these steps to make sure you have cem...
wp-content_uploads_2018_09_New-Profile.png wp-content_uploads_2018_09_Export-Profile-1.png
3D Navigation - Incremental Drawing
What is Incremental Drawing? If the speed of the 3D-explore falls below a predetermined value, ARCHICAD starts to leave out elements during the navigation. It continues until the speed reaches again the desired one. It eventuates working faster with ...
wp-content_uploads_2018_06_OpenGLOptions-1024x960.png wp-content_uploads_2018_06_Regedit-1024x375.png wp-content_uploads_2018_06_Prefedit-1024x375.png
Elements are disappearing during 3D navigation
Affected version: 22 | Severity: workaround applicable | ID: 243380 Issue During navigation in 3D with ARCHICAD 22, some elements can disappear temporarily. It can be experienced that opening the same project with ARCHICAD 21 and 22 on the same compu...
Element Previews do not work in Schedule Headlines
Affected versions: ARCHICAD 27and older | Severity: workaround applicable | ID: 140886 Issue: If the first row(s) or column(s) of an Interactive Schedule display element previews (such as 2D Plan Preview, 2D Cross Section Preview, 3D Axonometry or a ...
Story management of Hotlinked modules
At Elements' Elevation you can choose out of two options: 1. Adjust Elevation to Story Structure of Host Project choosing Adjust Elevation to Story Structure of Host Project will place the elements of the source file according to the Stories of the h...
wp-content_uploads_2017_08_Screen-Shot-2017-11-03-at-14.59.34.png wp-content_uploads_2017_08_Screen-Shot-2017-11-03-at-14.51.33.png wp-content_uploads_2017_08_Screen-Shot-2017-11-03-at-15.18.23.png wp-content_uploads_2017_08_Screen-Shot-2017-11-03-at-14.51.44.png
Attribute Management of Hotlinks
General Attribute management concepts When hotlinking a Module file into another file, the necessary, but not all attributes (layers, line types, complex profiles, etc...) of the source file will be appended to the attributes of the host file. This m...
Tips to Keep Your Projects Tidy
The more Attributes are collected in a Project, the more difficult it becomes to work with. Lots of Layers, unused Fills, Line types can slow your work down as you might spend too much time selecting attributes you want to use from their lists. Some ...
How to clean up Attributes in Archicad?
Line and Fill Normalization Several Archicad features involve the creation of “exploded” elements. Model-based Details, Worksheets and Drawing Sections create 2D elements (lines, fills) out of the model construction elements. Also, imported DWG drawi...
wp-content_uploads_archicadwiki_linefillnormalization--l01.jpg wp-content_uploads_archicadwiki_linefillnormalization--l02.jpg wp-content_uploads_archicadwiki_linefillnormalization--l03.jpg
Intersections in Layer Combinations Add-On
In ARCHICAD 8 and subsequent versions, intersection cleanup is linked to the Intersection Group Numbers assigned to layers. Elements which belong to layers having the same Intersection Group Number will intersect, regardless of layer visibility. Elem...
wp-content_uploads_2017_05_01-introduction-1-1024x593.png wp-content_uploads_2017_05_02-menu-location.png wp-content_uploads_2017_05_03-explanation.png wp-content_uploads_2017_05_04-before-1024x618.png
RAL Color System Add-On
RAL Colour Standards are developed and controlled by the German Institute of Quality Assurance and Trademark Control. The 194 classical shades (RAL 840-HR) and the RAL Design System with its 1688 colors are both well known in a number of industries, ...
wp-content_uploads_2017_05_Options.png wp-content_uploads_2017_05_TestFiles.png wp-content_uploads_2017_05_840-HR.png wp-content_uploads_2017_05_RALDesignSystem.png
Polygon Counting Tool Add-On (PolyCount)
PolyCount is an ARCHICAD add-on that helps you control the number of 3D polygons in your ARCHICAD models. This tool can be used effectively if the project size or the limited physical memory of your computer makes the 3D model size a critical factor ...
wp-content_uploads_2017_05_polypalette.png wp-content_uploads_2017_05_polydetailed.png
Check Duplicates Add-On
This ARCHICAD Add-On can find, select, or delete items sharing the same parameters (type, color, thickness, height, etc...) and occupying the same spot on the floor plan. Unwanted doubles are typically created by either accidentally double-clicking a...
wp-content_uploads_2017_05_01-200x300.png wp-content_uploads_2017_05_02-select-1-300x169.png wp-content_uploads_2017_05_03-delete-1-300x220.png
Construction Simulation Add-On
In previous versions, the set of commands will appear in the Document/Schedules and Lists/Construction Simulation submenu by default. Since AC20 you can find it under Document/Listing Extras/Construction Simulation. The commands of the Construction S...
wp-content_uploads_2016_06_Info_18x18.png wp-content_uploads_2017_04_0001-1-1024x642.jpg wp-content_uploads_2017_04_Screen-Shot-2017-04-28-at-13.23.30.png wp-content_uploads_2017_04_Screen-Shot-2017-04-28-at-11.02.31.png
Tips to use the Project Information
Introduction During the lifetime of a project it is essential to manage project related information such as the exact name, address and contact info of the architect, those of the client, location of the building site, etc. These are important in sev...
wp-content_uploads_2013_05_01-groups.png wp-content_uploads_2013_05_02-address-1024x464.png wp-content_uploads_2017_02_03-autotext-1-1024x592.png wp-content_uploads_2017_02_04-autotext-1.png
Why Dimensions and Zones can't be part of a group
You have probably noticed that Dimensions and Zones can't be part of a group but you were wondering why. This is because these elements almost always have relation to other elements (dimensions belong to walls or other elements, zones are relative to...
wp-content_uploads_2011_06_01_module-1024x576.png wp-content_uploads_2011_06_02_hotlinked-1024x576.png wp-content_uploads_2011_06_03_after-break-1024x578.png wp-content_uploads_2011_06_04_after-ungroup-1024x577.png
The complexity of a plan, especially the 3D model mainly depends on how many polygons it contains. Polygons are the most basic 2 dimensional plain geometric elements that form the 3D model. Polygon Counting Tool is an ARCHICAD add-on that helps you c...
wp-content_uploads_2013_05_download-1024x659.png wp-content_uploads_2013_05_installer.png wp-content_uploads_2013_05_add_on-manager-639x1024.png wp-content_uploads_2017_02_palette.png
AutoSave Files
The Autosave function controls a number of options protecting you against losing work in case of a program or system crash, power outage or sudden termination of the program. If you are experiencing one of these, then the next time you launch ARCHICA...
wp-content_uploads_2012_10_ACprojectRecovery-1.png wp-content_uploads_2012_10_AutoSaveFolder.png
  • 28858 Views
  • 0 comments
  • 2 likes
How to Transfer Projects to Another Computer
This article discusses the process of transferring the ARCHICAD Projects, Libraries, Images, Linked Files from one computer to another. Step 1: Export Projects, Library Items and Drawing Files To ease your further work with ARCHICAD projects on anoth...
wp-content_uploads_2017_01_save-as-dialog.png wp-content_uploads_2017_01_save-as-pla.png wp-content_uploads_2017_01_warnings-all-1024x556.png wp-content_uploads_2017_01_after-consolidation-1-1024x480.png
ARCHICAD 20 - Using Favorites in the Toolbox
More information: http://archicad.com/ This video clip explains how Favorites are used in the Toolbox in ARCHICAD 20. Graphical Favorites can now be applied directly from the Toolbox in ARCHICAD 20.Free ARCHICAD Download: http://www.graphisoft.com/do...
Quick Menu Item Access on Mac
On Macs running Snow Leopard (10.6) and newer there is an awesome search field in the menu bar. If you cannot remember where a menu item is located in the menu structure, you can use this search field to quickly access the command. You can either per...
wp-content_uploads_archicadwiki_searchmenu--search.png wp-content_uploads_archicadwiki_searchmenu--pref.png
