Archicad design tools: Workflows, element connections, modeling tips
Articles
What if one single tool could carve wall niches, punch a clean multistory shaft, and transform a flat facade into a historical style elevation? The Opening Tool in Archicad 29 does all three, and this article walks you through each workflow. Carving a niche in section The Op...
  • 1853 Views
  • 0 likes
  • 0 comments
This article describes how to calculate the total area covered by multiple roof (or slab) elements on a site, including the percentage of rainfall or site coverage, while correctly accounting for overlapping regions in Archicad. It is useful when an accurate, verifiable roof...
  • 1473 Views
  • 0 likes
  • 0 comments
Aligned axonometric views are often required for consistent visual output across multiple floor levels, especially when preparing rendered images. This article describes a workflow that ensures consistent alignment when adjusting the 3D cut plane. Issue description When modi...
  • 681 Views
  • 0 likes
  • 0 comments
Modeling timber beams and roof trusses for joinery or fabrication often requires displaying exact cuts, notches, or connection details directly on the beam elements in the model. Instead of duplicating geometry or editing complex profiles, the Opening Tool can be used to cre...
  • 647 Views
  • 0 likes
  • 0 comments
Symbol Fills in Archicad normally rely on linework-only patterns, which can limit the appearance of hatching and 2D documentation fills. By embedding fills inside a Symbol Fill definition, patterns can combine lines, arcs, hotspots, and filled areas in a single attribute, re...
  • 1026 Views
  • 0 likes
  • 0 comments
When point clouds are used as a reference in a project, the high density of points can make it harder to place and edit elements accurately. This article describes several ways to reduce visual clutter, manage snap behavior, and keep point clouds usable as a reference while ...
  • 978 Views
  • 0 likes
  • 0 comments
An accurate model must match the segmentation between the two elements — when the slab and the wall have different curve resolutions, their edges may not align perfectly, causing gaps or overlaps. This article explores two practical techniques to ensure precise alignment bet...
  • 930 Views
  • 0 likes
  • 0 comments
When working on large projects, it is often necessary to update specific parameters of many elements at once without changing anything else. This article describes two methods in Archicad that help update only the intended parameters while keeping all other settings unchange...
  • 1033 Views
  • 0 likes
  • 0 comments
Presenting beams with angled ends in floor plan views requires a clear approach to ensure the geometry is shown accurately for documentation and communication. This article explains a practical modeling strategy to display beams with angled start or end faces on either a ver...
  • 742 Views
  • 3 likes
  • 0 comments
Boosting speed in Archicad often comes down to cutting out repetitive steps, and a few targeted shortcuts can make everyday edits feel almost instant. This article highlights four powerful keyboard workflows in Archicad 29 that help rotate, copy, resize, and match styles wit...
  • 4570 Views
  • 1 likes
  • 0 comments
The Multiply command in Archicad quickly creates multiple copies of selected elements, keeping spacing, pieces or both consistent and saving time with repeated items like columns, lights, or beams. It can copy elements in a line, arc, radial pattern, grid or along a selected...
  • 3087 Views
  • 2 likes
  • 0 comments
Archicad provides various modeling features for precise building geometry adjustment. Let's see those which are for adjusting other elements to roofs/shells and for creating complex shapes using Boolean operations. Crop to Single-plane Roof, Trim Elements to Roof/Shell, and ...
  • 2638 Views
  • 0 likes
  • 0 comments
Did you know you can adjust layer thickness of complex profile walls without creating new walls? To adjust complex profiles in Archicad without rebuilding elements, use Offset Modifiers to dynamically edit layer thicknesses, dimensions, and surfaces. This method saves time b...
  • 3201 Views
  • 1 likes
  • 0 comments
Are you still placing your reference image directly on the ground floor and struggling to navigate your project? If you're tired of jumping between views and losing your place, Trace & Reference is the smarter, more efficient way to work in Archicad. What is Trace & Referenc...
  • 5978 Views
  • 0 likes
  • 0 comments
Do you feel limited by your current Curtain Wall skills? Here are some key settings to unlock new design possibilities and create stunning, customized facades in Archicad. Watch the video for the detailed steps! Step 1: Create a Custom Panel One of the most powerful ways to ...
  • 6009 Views
  • 1 likes
  • 0 comments
Did you know you can make magic in Archicad? Let me show you how Magic Wand can make you work easier and more efficient! What is the Magic Wand? The Magic Wand is a feature in Archicad that detects and traces shapes from existing elements or empty spaces. It allows users to ...
  • 2820 Views
  • 1 likes
  • 0 comments
Did you know you can test different designs in Archicad without saving separate files or copying elements around? With Design Options, you can explore alternatives for facades, layouts, materials, and create combinations to find the best match. Here’s how it works: How to us...
  • 4043 Views
  • 2 likes
  • 0 comments
Pickup Parameters in Archicad allow you to quickly transfer settings from one element to another, streamlining your workflow and ensuring consistency across your project. Here are some cool tips on the Pickup Parameters that will simplify your work in Archicad: Need a New Wi...
  • 3728 Views
  • 1 likes
  • 0 comments
Do you ever get confused when designing stairs in Archicad? We know it's a super parametric tool, so... Let's break down the five key settings to help you design better! Baseline What is it? The baseline determines the reference line for your stairs. How to set it: Align the...
  • 2633 Views
  • 4 likes
  • 0 comments
The BIMmTool is an Archicad add-on designed specifically for importing, analyzing, modeling, controlling, and archiving point clouds, fully supporting Scan2BIM workflows. This tool is seamlessly integrated within the Archicad environment to facilitate all workflows involving...
  • 16741 Views
  • 6 likes
  • 0 comments
Dynamic or movable facades have emerged as a captivating architectural element, enhancing both the visual appeal and functional efficiency of modern buildings. These adaptable designs introduce motion and versatility, contributing to energy efficiency and creating a favorabl...
  • 5212 Views
  • 19 likes
  • 0 comments
In Teamwork, several users can work with Design Options, even if one has reserved the Design Options Manager. While this gives flexibility, it might also lead to conflicts if users have not received changes for a while. For example, one of your team members deletes an Option...
  • 5698 Views
  • 7 likes
  • 0 comments
Archicad 27 introduces an innovative tool that will enhance the experience of architects and designers managing multiple design options, helping the decision-making process be more seamless and efficient. This article dives into the new feature of Archicad 27 - Design Option...
  • 14925 Views
  • 4 likes
  • 0 comments
I recently came across a project from my first year as an architecture student, and since the paper model I had is long gone, I thought of modelling it with Archicad so as to keep record of it for my portfolio. The building is a 2-story family house, on a sloped site. What I...
  • 9837 Views
  • 24 likes
  • 0 comments
The Opening Tool is more precise and flexible The Opening Tool is one of the most frequently used Archicad tools in any project for the modeling, information management, and documentation of openings. Prior to Archicad 26, openings automatically used the same surfaces as the...
  • 11199 Views
  • 4 likes
  • 0 comments
Note: This article was originally published on AsiaBIM and was written for Archicad 21 mainly for architects working on the Singaporean market.Some users like to have their own 2D representations created with lines and fills for the default window with a little bit GDL scrip...
  • 6797 Views
  • 7 likes
  • 0 comments
A quick way of inserting the representation of the terrain to our model is using the point cloud import feature of Archicad. Point clouds are more and more popular since they can give the most detailed surveying results, however at the same time need some touch up for archit...
  • 21325 Views
  • 14 likes
  • 0 comments
Prepare the AutoCAD file Open Surveyor’s dwg file and check whether it is done as per local practice/standards, for example: Units = Meters Block or Point is used to represent each survey point and placed at a correct global coordinate (X,Y,Z) – Use LIST command and pick the...
  • 25232 Views
  • 11 likes
  • 0 comments
Place a Ramp Object I felt it is good to share some software specific tips and tricks in between my posts focusing on interoperability. In this post I am sharing a tip on how to create guard walls (parapets) along the edge of a curved ramp using Morph Tool and Solid Element ...
  • 5538 Views
  • 3 likes
  • 0 comments
One kind of a recurring issue is how to create the frameless corner windows, using just a mitered glass connection as below: Switching to the Custom Corner… tab page of the Window settings however doesn’t allow us to choose Glass, but Frame or Corner Column only. The trick i...
  • 5445 Views
  • 2 likes
  • 0 comments
Adding new nodes to a Wall when editing it via the Pet palette eventually creates segments which cannot be joined again using an inverse command or such. Though it is not something you could not solve by deleting one of the segments and edit the remaining part, the method is...
  • 7731 Views
  • 3 likes
  • 0 comments
In this article I will be focusing on a simple example to demonstrate RH-GH-AC live connection, another wonderful OPEN BIM workflow from Graphisoft. We will start with an input from a Archicad (AC) file and based on that input a set of balconies will be created using Grassho...
  • 6765 Views
  • 4 likes
  • 0 comments
Recently came accross a situation where the Design Architect need to exchange Archicad model with their project partners. The Main Contractor was using REVIT for their BIM process. So, there was a need for conversion of Archicad model to REVIT model via IFC. The project has ...
  • 5650 Views
  • 4 likes
  • 0 comments
Archicad Meshes can be created in many different ways – by creating level ridges based on external drawings, by importing point clouds and modeling the terrain based on it or importing text files with the coordinates and then let Archicad automatically build the terrain.The ...
  • 8660 Views
  • 3 likes
  • 0 comments
Creating custom components from scratch using the default tools and saving them as objects is a relatively simple way to extend the content libraries thanks to the File/Libraries and Objects…/Save Selection as… command. However this menu doesn’t list Curtain Wall Junctions a...
  • 5726 Views
  • 5 likes
  • 0 comments
There seems to be a clash between design sketch models (typically coming from SketchUp or Rhino, but even if they are created with Archicad) and models created for proper BIM use when we need to convert one to the other since they are built with completely different approach...
  • 5182 Views
  • 2 likes
  • 0 comments
Welcome to our series of articles from the Snow Globe Challenge! We invited some of the designers who participated in the challenge to elaborate on their entries, share their workflows and tips&tricks. Enjoy and feel free to drop us a comment if you have any questions. Now p...
  • 5022 Views
  • 4 likes
  • 0 comments
Welcome to our series of articles from the Snow Globe Challenge! We invited some of the designers who participated in the challenge to elaborate on their entries, share their workflows and tips&tricks. Enjoy and feel free to drop us a comment if you have any questions. Pleas...
  • 5784 Views
  • 5 likes
  • 0 comments
Welcome to our series of articles from the Snow Globe Challenge! We invited some of the participants of the challenge to elaborate on their entries, share their workflows and tips&tricks. Enjoy and feel free to drop us a comment if you have any questions. Welcome Sepideh Kol...
  • 6509 Views
  • 8 likes
  • 0 comments
  • 6055 Views
  • 8 likes
  • 0 comments
In order to efficiently model a basement stair and bulkhead door (i.e. not creating extra cutting bodies) elements need to be created and cut in a specific order. These steps are listed below 1. Make sure that a mesh has been placed around the outside of the foundation walls...
  • 7003 Views
  • 5 likes
  • 0 comments
Follow the steps below to create a railing with evenly spaced posts that follows the contour of a mesh. 1. Create a poly line where the railing will be. 2. Open the Set Snap Point Values dialogue box. 3. In the Snap Point Values dialogue box, set the Distance the posts will ...
  • 7428 Views
  • 6 likes
  • 0 comments
Creating and editing stairs requires to handle and consider multiple- many time contradicting- requirements. Ensuring all these factors across the design changes is challenging task for all architects. Archicad 25 brings improvements to the Stair Tool that ensure design free...
  • 7060 Views
  • 2 likes
  • 0 comments
This original article is written by Chidam and can be found at ASIABIM: https://asiabim.wordpress.com/2017/02/15/editable-topography-from-archicad-to-revit/ Occasionally, the Designer needs to exchange BIM models with other project partners. If each stake holder uses differe...
  • 6744 Views
  • 5 likes
  • 0 comments
MEP Modeler Add-On has become the core part of Archicad 24 as an integrated design tool. The second update of Archicad 24 includes major MEP improvements primarily for increasing effectiveness. This article describes a new feature and further enhancements for using the MEP M...
  • 7505 Views
  • 2 likes
  • 0 comments
Many times we want to show a slab or a mesh on a story above or below its home position. To control which story a slab or mesh is displayed, there are some presets that can be found under Slab/Mesh Settings dialog: Floor Plan and Section > Floor Plan Display > Show on Storie...
  • 6256 Views
  • 0 likes
  • 0 comments
The volume of soil excavation for a project can be calculated in many ways. However, this process can be automated, making the workflow easier and faster by using the Opening Tool. The Opening geometry is measured relative to its associated element and moves along with it, w...
  • 6202 Views
  • 3 likes
  • 0 comments
The BIM collaboration between architectural, structural and MEP engineering disciplines needs software solutions that aid this collaboration. It is becoming more usual for engineers to take part in the design process and work with architects starting from the initial phases ...
  • 15510 Views
  • 2 likes
  • 0 comments
Grasshopper is a visual programming language and environment that runs within the Rhinoceros 3D for creating Parametric Designs. To ensure the interoperability between the software and have a smooth workflow, Archicad has the toolset: "Grasshopper - Archicad Live Connection"...
  • 31542 Views
  • 2 likes
  • 0 comments
What is algorithmic design? If you are not yet familiar with this term, watch this video below: Rhino – Grasshopper – ARCHICAD Toolset Rhino – Grasshopper – ARCHICAD Toolset connects the best design tools for the different design stages on both Mac and Windows platforms. The...
  • 16746 Views
  • 3 likes
  • 0 comments
In certain cases when users are modelling open or closed stringer stairs, the corner stringer piece does not get created, or gets created but the geometry of it is faulty. The reason behind such issues always lies in some kind of geometrical controversy. Stairs are complex e...
  • 5588 Views
  • 3 likes
  • 0 comments
With the Grasshopper - Archicad Live Connection, you can enhance your BIM model with complex shapes that can not be defined easily with the defaultArchicad tools. In order to be able to properly represent and document these shapes, while keeping the geometry and BIM informat...
  • 7225 Views
  • 4 likes
  • 0 comments
With the Grasshopper - ARCHICAD Connection tool, you can enhance your BIM model with complicated shapes that can not be defined easily with the default ARCHICAD tools. To be able to properly represent and document these shapes, while keeping the geometry and BIM information ...
  • 6814 Views
  • 0 likes
  • 0 comments
Parameter transfer, also known as the eye-dropper and syringe, is the easiest way to pick up the parameters of one element and transfer them to another element of the same type. Simple usage of these tools allows you to speed up your pace while drawing your project. What is ...
  • 6910 Views
  • 1 likes
  • 0 comments
This exercise is about creating a prefabricated concrete double-pitch beam used for building industrial halls. Due to the renewed, multi-segmented Beam and Column tools it is much easier to create such structures in ARCHICAD 23. The shape of the beam can be defined with the ...
  • 6139 Views
  • 0 likes
  • 0 comments
In ARCHICAD 22 and before all columns were cut horizontally at the bottom and at the top and all beams were cut vertically at both ends. As of ARCHICAD 23 beam and column ends can be cut both horizontally and vertically and also at any custom angle. As of ARCHICAD 23 beams a...
  • 7411 Views
  • 0 likes
  • 0 comments
This article presents you with the detailed process of modeling a prefabricated reinforced concrete column with the new Column Tool of ARCHICAD 23. Prefabricated columns are often used in the case of industrial halls. The easiest way to represent these structures in ARCHICAD...
  • 7763 Views
  • 1 likes
  • 0 comments
What is a Segment? Beam (or Column) Segments are good for defining different materials and geometries along the Beam (and Column) reference axis. The result: expanded geometric freedom for BIM elements representing reinforced concrete, steel, timber, and composite Beam and C...
  • 7656 Views
  • 2 likes
  • 0 comments
The Opening Tool is one of the new features of ARCHICAD 23, a must-have BIM design tool for the modeling, information management and documentation of openings. Use the new Opening Tool to create holes and recesses/niches that penetrate any number of model elements. They are ...
  • 10313 Views
  • 0 likes
  • 0 comments
In Archicad the flexibility is given for just sketching up the building without having to numerically specify the correct size or location of an element, but if it's coming to a proper design process, you have to place the elements with a certain size and position. With the ...
  • 7458 Views
  • 1 likes
  • 0 comments
Architects often receive the surveyor's data in the form of a 2D linework with height values. Follow the steps below to model the terrain based on the 2D linework. Create a mesh using the Mesh Tool, following the outer contour of the linework Select the mesh and activate the...
  • 55874 Views
  • 1 likes
  • 0 comments
The Wood Ceiling add-on allows users to apply 3D wainscoting to an existing roof. Before Starting 1. Download and install the Goodies package here. 2. Add the Accessories Library to the project library. It is located under the ArchiCAD version folder under the Graphisoft fol...
  • 5018 Views
  • 0 likes
  • 0 comments
The Roof Surfacer add-on allows users to apply 3D cladding to an existing roof. Before Starting 1. Download and install the Goodies package here. 2. Add the Accessories Library to the project library. It is located under the ArchiCAD version folder under the Graphisoft folde...
  • 16774 Views
  • 0 likes
  • 0 comments
If you drag an element in a section or in 3D to a different story, the Home Story of the element won't be adjusted. So, it can happen, that an element is located on e.g the 1st story but it has a different Home Story. (To avoid issues like that use 'Edit Elements by Stories'...
  • 9209 Views
  • 1 likes
  • 0 comments
Trim function helps you to edit the existing elements quickly and easily in 2D and 3D. This is done by CTRL-clicking (on Windows) / CMD-clicking (on Mac OS) elements on the Floor Plan. One can cut off unneeded portions of Walls, Lines, Arcs etc., split them in two pieces or ...
  • 18241 Views
  • 1 likes
  • 0 comments
When using magic wand to place a morph, it will become polygonal instead of a proper circle. Why? It's easy to come across this phenomenon. We place a circle and then use the Magic Wand to place a Morph surface within. You will notice, that the segmentation of the Morph prob...
  • 4813 Views
  • 1 likes
  • 0 comments
For entering distances in Archicad the Tracker is used. Entering distances works the same way in 2D and in 3D. The Tracker appears during element input and it follows your mouse movements, constantly providing feedback about the distance and angle or/and the XYZ coordinates ...
  • 37198 Views
  • 1 likes
  • 0 comments
The Curtain Wall tool has been renewed as a powerful design tool allowing also the creation and use of custom frames and custom panels. In the previous versions the user was able to toggle between a main and a distinct panel and also manually change the panels. Additional to...
  • 6858 Views
  • 2 likes
  • 0 comments
With the new Curtain Wall tool, released on ARCHICAD 22 Version, it is possible to create many different Panel Classes straight from the Curtain Wall Setting Dialog. You can even create a Cladding Panel using the new GDL Panel Type called CW Composite Panel 22. For that, ope...
  • 11285 Views
  • 1 likes
  • 0 comments
Use the Scheme page of Curtain Wall Settings to set up a Grid Pattern for the Curtain Wall. The best way to start a custom grid is deleting any existing grid. For that click on the Clear Pattern button on top right side of the scheme preview window. Trick: Before start addin...
  • 6501 Views
  • 0 likes
  • 0 comments
Before the revamped Curtain Wall Tool was released in ARCHICAD 22, intersection priorities were taken in count when creating a Curtain Wall, but not used as a creative tool. Boundary, Mullion and Transom frames did have a priority, but these were fixed numbers. With the rele...
  • 4888 Views
  • 2 likes
  • 0 comments
We're famous for having Tools that can be used for more than their original function. Profiles are used in Walls, Beams, and Columns to create custom elements tailored to the project. Use the parametric profiles to create design alternatives and custom furniture using only o...
  • 4526 Views
  • 1 likes
  • 0 comments
After the redesign of the Curtain Wall Tool in ARCHICAD 22, it can have different projection modes on a floor plan view (found under Floor Plan and Section in the element's Settings dialog). These can be set for Uncut, Cut and Overhead components, similar to the Floor Plan D...
  • 4433 Views
  • 2 likes
  • 0 comments
As a newly introduced feature in ARCHICAD 22, the parametricity of profiles can be used for multiple purposes. One of them is to create adjustable fireproofing/insulation for beam or column elements. Later, the thickness can be adjusted by element, letting us use only one Pr...
  • 4404 Views
  • 2 likes
  • 0 comments
A Wall element can be a simple wall and it can also use composites or profiles. Composite structures can be used with Shell, Roof, and Slab elements as well, and can have up to 48 skins with individual skin separator lines However, since with ARCHICAD 22 complex profiles wit...
  • 5152 Views
  • 2 likes
  • 0 comments
With parametric profiles being introduced in ARCHICAD 22, came new attributes to manage, the offset modifiers. With the help of the Modifiers, you can create more intelligent Profiles for Walls, Beams, and Columns, by defining the edges parametrically in the Profile Editor. ...
  • 5470 Views
  • 1 likes
  • 0 comments
Step 1: Set Project Location in Project Preferences This will be the place in the real world where your Project Origin is Set the height above Sea Level. You can reconfirm the location by clicking on "Show in Google Maps…" button. Step 2: Add an Aerial Photo to the Project G...
  • 10333 Views
  • 0 likes
  • 0 comments
How to use Accessories Add-on With the help of this Archicad Add-On, you can supplement the roof, slab, and wall elements with special objects. Make sure you add the Accessories Library to your project, using Library Manager. First, select an existing building element (wall,...
  • 187658 Views
  • 5 likes
  • 0 comments
Turning stairs can be constructed in 2 different methods: using turning type method or segment type method. Let's have a quick look at the main aspects of those two types. Turning Type Turning type can be used in 3 ways: Landing Winder with Equal Angles Winder with Equal Goi...
  • 6413 Views
  • 0 likes
  • 0 comments
In a previous Article we have explained how Stair Segments and Turnings work in General. In this article we will show you 2 examples of how to use them to create Stairs that have winders with Equal Goings/Runs. About Winder Options You can open the winder options dialog eith...
  • 14241 Views
  • 0 likes
  • 0 comments
In a previous Article we have explained how Stair Segments and Turnings work in General. In this article we will show you 2 examples of how to use them to create Stairs with Equal Angle winders, and explain how this winder type works in general. How Winder with Equal Angles ...
  • 11580 Views
  • 0 likes
  • 0 comments
The new Stair and Railing Tools use GDL sub-elements (such as posts, rails, etc.). Many of them are pre-defined and available by default through the element and component settings dialogs. You can find several default objects in the stock ARCHICAD library, but you can also c...
  • 10128 Views
  • 5 likes
  • 0 comments
The new Stair and Railing Tool include GDL sub-elements. Many of them are pre-defined and available by default, through the element and component settings dialogs. To create your own sub-element, you can create and customise an element and save it as a specialised Library Pa...
  • 16685 Views
  • 2 likes
  • 0 comments
There are many ways to create a ramp in ARCHICAD (e.g., Ramp Object), but in this article, we are going to show you how to create one with the help of the Stair Tool. Here is what you will need: a complex profile a Stair with stringers that's all Structure Create a custom pr...
  • 29213 Views
  • 6 likes
  • 0 comments
This article shows general examples of how to create Metal Plate and Metal Pan Stairs. The two types are very similar to each other in structure, so the way to create them is similar as well: We will use a cantilevered structure, with profiled stringers, without finishing. F...
  • 8466 Views
  • 1 likes
  • 0 comments
This article explains methods of enhancing the appearance of connections of floors and walls in model section views. Description of the floating floor screed edge detail In most cases the solution for floors to match soundproofing requirements is to design a so called floati...
  • 5889 Views
  • 1 likes
  • 0 comments
Creating Favorites hasn't changed with the Stair and Railing Tool. Since it is a hierarchical element, it is a very similar method creating Favorites for a Curtain Wall and its sub-elements. Favorites for Stairs Stair: Structures and Finishes Once you set up the settings for...
  • 5377 Views
  • 1 likes
  • 0 comments
This article covers ARCHICAD tools that are available in the Grasshopper - ARCHICAD Live connection and their necessary Grasshopper reference geometries complemented with tips & tricks for the different tools. Wall Necessary input: planar 2D curve (line, polyline, curve) in ...
  • 6770 Views
  • 0 likes
  • 0 comments
In this article we are going to create an Open Stringer Stair. To achieve this type of Stair structure, we will choose 'Beam' structure for the flight (and landing). For the opposite edge of the Stair add Stringer by ticking the box, optional 'Stringer Left' or 'Stringer Rig...
  • 8357 Views
  • 0 likes
  • 0 comments
In this article we will show you how to create a traditional cast iron Railing from Custom Panels. Draw the two following shapes from Morph – Surface, and then extrude them in 3D by 15 mm. These shapes will be our Custom Panels. Make sure you rotate your shapes according to ...
  • 9324 Views
  • 2 likes
  • 0 comments
In this article we will show you how to create a cantilevered stair with wedge-shaped steps. First a cantilevered, spiral stair will be placed. Then a Custom Tread will be created for having wedge-shaped steps. Draw two concentric circles, d1=1600, d2=3100. Select the Stair ...
  • 5807 Views
  • 1 likes
  • 0 comments
To place a stair you need to draw its Baseline (blue line), which is basically a polyline. So the input and the connected Pet Palette options are similar to placing the polyline in ARCHICAD. The Stair 'Input Method' (Upward / Downward) defines wherever the first click define...
  • 10781 Views
  • 0 likes
  • 0 comments
This article provides a step-by-step description for creating a metal spiral stair having a column in the middle. The unique thing in this example is that the structure of the staircase is part of the tread. To see how to place a general spiral stair, click here. Placing a s...
  • 13842 Views
  • 1 likes
  • 0 comments
Archicad approaches the design workflows strongly level-based – it is of great significance to which story the elements belong. As a consequence of that, the planning of buildings with split levels may be slightly more difficult in certain cases. This article would like to g...
  • 26635 Views
  • 3 likes
  • 0 comments
You can easily create frameless corner windows in ARCHICAD the way described below: You can use the simple Window Tool instead of the Corner Window Tool, however not all Window objects are suitable for this. In this example I used the Horizontal Multi-Sash Window 21 object. ...
  • 9283 Views
  • 0 likes
  • 0 comments
The new Stair Tool has the feature to add landing automatically during creation of the stair. Landing length can be defined in the Stair Settings under Rules & Standards: Automatic landing can be placed with one click during Stair creation. Start with creating a stair. After...
  • 13051 Views
  • 1 likes
  • 0 comments
Introduction This article presents how to create a glass panel railing with posts. We used an L-shaped staircase where the Riser Offset is set to 0. In this case only one post will be added by the intersection point of the two flights. Let's start Activate the Railing Tool. ...
  • 12068 Views
  • 1 likes
  • 0 comments
